01-23-2021, 11:34 AM | #1 |
Rep 49
No Drill Front License Plate Options
I've seen this topic on the G05 and other forums but don't believe it's been discussed on our F95.
I live in a state that requires a front plate and I'd like to use a no drill option in the center of the bumper. After doing some research I think Carbonio might be the best option but I can't seem to find too many pictures of how this would work or fit on my F95 with ACC. Anyone here use Carbonio or other no drill mounts for their front plates? Also hear some people using Sly Brackets but I don't think they offer a non-offset option. Link for reference: https://carbonio.com/products/bmw-x3...r_2021~md_x5-m |
01-23-2021, 12:34 PM | #2 |
Rep 687
For my E90 M3, I used a tow-hook screw thing that screwed a plate-holder into the tow-hook receptacle, the plate was offset from center, but I think it looks good.
Is there a knockout on the front bumper for a tow-hook screw on the X5M? If so, that might be an option. |
DCCane33.50 |
01-23-2021, 01:29 PM | #4 | |
Rep 49
01-23-2021, 01:30 PM | #5 | |
Rep 49
01-23-2021, 01:46 PM | #6 |
Rep 81
When I was researching for mine a lot of the non offset ones are universal that have brackets that attach to the mesh/grill. Otherwise there are ones that mount with hardware (drilling required) on the bottom side of the bumper.
01-23-2021, 01:54 PM | #7 | |
Rep 49
01-23-2021, 02:09 PM | #8 |
Rep 81
01-23-2021, 02:45 PM | #9 |
Rep 687
Anyone know if it’s legal to manufacture or purchase a “Euro-style” long skinny front plate that would have the same numbers/letters as your back-of-car state-issued plate?
01-23-2021, 03:21 PM | #10 | |
Rep 8,790
Drives: eVeRyOnE mAD!
BUT if it's a legal requirement to have a front license plate, I highly doubt you'll get away with it as it's a state-regulated item. EDIT: you could mount a front euro-style plate in addition to your legal plate, but I'm pretty sure that defeats the look you're going for ;P |
01-26-2021, 10:51 AM | #12 | |
Rep 20
01-28-2021, 03:50 PM | #13 | |
Rep 733
Thanks in advance
'23 F93 M8 GC ZCP - HRE S101SC - Full Akrapovic - '15 Audi R8 4.2 S-Tronic (Past) YouTube '21 F96 X6M ZCP Akrapovic/MSS/BC Forged, ‘18 G30 M550i, '18 G01 X3 M40i, '15 F10 M5 ZCP HRE S101 #1 & #2/Akrapovic, ‘13 W204 C63 AMG - ADV1 5.01SL's |
01-28-2021, 09:40 PM | #14 |
Rep 296
Thankfully Ohio doesn't require a front plate as of July 2020. That said, I went 4 years without one because I refused to drill holes. I only got one ticket that entire time and it was from a meter maid. No traffic stops (and I had a few ! ) ever said anything.
01-29-2021, 10:51 AM | #15 | |
Rep 20
https://carbonio.com/collections/bmw...se-plate-mount |
02-13-2021, 11:46 AM | #16 |
Rep 49
Updating with pics. Decided to go with the Carbonio front plate mount. Haven't tested for a long duration or at high speeds but appears to be a decent option for those looking for a non-drill, non-offset option for their front plate.
I need to play around with the bracket because it's still a little crooked. Also note for anyone buying this that you can't mount on the top "full rung" as provided for in the instructions, instead you need to go to the very top "half rung" above that in order to avoid triggering the ACC sensor. |
02-15-2021, 12:33 AM | #17 |
Rep 8,790
Carbonio
might I suggest some type of leveling mechanism to adjust for tilt? |
02-16-2021, 04:40 PM | #19 |
Rep 764
Drives: '23 BMW i7 xdrive60
When driving at highway speed, won't the top screws hit the bumper and scratch it?
'23 BMW i7 xdrive60 - Frozen Deep Grey
'22 BMW 228xi Gran Coupe - Phytonic Blue |
02-16-2021, 05:56 PM | #20 |
Rep 49
There are two black bumper-like pieces that come with the kit to protect from scratches. I'll also try to play around with the tilt and see if I have any luck.
02-17-2021, 09:56 AM | #21 |
Rep 20
Correct the kit comes with rubber bumpers to protect the paint. We have found that the best thing is to mount the plate with the rubber bumpers physically touching the bumper and even better pre-loaded with some natural 'spring'. This can be achieved via the side adjustment screws that allow the setting of angle and distance.
Physically touching the bumper is advantageous to a small air gap because it eliminates the possibility to gain momentum against the paint that can damage it. We ran this strategy on a car for over 2 years in all kinds of weather and when the bracket came off there was not the slightest bit of damage to the bumper. |
GrussGott18198.00 |
03-07-2021, 08:11 PM | #22 |
Rep 92
Drives: 2015 Toyota Tundra Limited
Carbonio I've looked at your brand heavily. However, I'm not quite sure the mount for 2021 X6 w/adaptive cruise control will fit. The grill on my 21 X6 is different from the examples on your website and other X6 I've seen in his forum. My front grill doesn't have the several rows of honeycomb as displayed on your pictures and instructions (see pic). Can you confirm the mount will fit? Thank you!
2021 BMW X6 (G06) x40i - Manhattan Green/Coffee - 02/2021
2017 BMW 740xi (G12) (SOLD) |
