03-31-2021, 12:37 PM | #1 |
Rep 13
Wanted: Used Rims and Tires for 2019 M850i Coupe (20")
Hello All - Anyone have any rims and tires or any combination of available for sale? Thank you! If you're in Southern California, even better! |
04-02-2021, 09:18 AM | #6 |
Rep 116
You might want to use an online wheel calculator to check these as the M8 wheels are a different offset than your m850i wheels as the M8 has more flared fenders. I asked this question before and got some good answers that resulted in the wheels/tires sticking out quite a bit beyond the fenders. Just a heads up before you buy. HTH.
2019 M850i Coupe
04-02-2021, 02:17 PM | #7 |
Rep 909
Indeed I'd evaluate it very carefully. I wanted some M8 wheels too but then decided it against it after doing some research. I am thinking about 21" wheels instead (Alpina or ACS perhaps) next season (my 20" tires still got lots of profile so will not be swapping 20" just yet).
For you, here is the comparison M850i original wheels vs original M8 ones: FRONT: https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm REAR: https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm I see "challenges" (front gets all too close to suspension components) and the rear will stick 5 cm further out. There is also some scrub radius to be taken into account though it isn't considerable in both cases. |
BigMofoFrog180.50 FlorinQCK-2.50 |
04-13-2021, 04:24 PM | #9 |
Rep 13
I wouldn't mind however the reason for this is because one of my rims may be damaged. If you're still interested in selling, PM me and we'll connect.
Resjudicata1604.00 FlorinQCK-2.50 |
