BMW M3 and M4 - The Icons
home
Technical Sections Suspension / Brakes / Chassis
      10-22-2021, 11:44 PM   #1
gotgemini2000
Drives: G80 & E46 M3, 6 speed manuals
Raising a G80 M3 1-2 inches for ripping around on gravel roads?
I live on a farm and often rip around on gravel roads pretty quick.
Debating buying an M3 - but want to be able to put 18 inch wheels on it and just lift it enough to be able to fly over gravely roads (my farm has 5 entrances, 4 of which are about 1/2 a mile over gravel).
Has anyone seen any 1.5-2 inch lifts that are not absurd, but give just enough clearance to pop over some gravel road (gravel roads get dicey especially after some rain, and we don't always grade stuff perfectly, so just need a bit more clearance)?
par__m3452.50
      10-23-2021, 04:40 AM   #2
CadHater
CadHater's Avatar
Germany
768
Drives: M3 Comp AWD
Sounds like you need an X3M/X4M.
2022 M3 xDrive - BSM/Tartufo
Appreciate 6
ROBERT11831581.00
Encanto1171.50
Neophyte158.00
      10-23-2021, 04:44 AM   #3
barryc365
Drives: BMWM3
KW makes lift kits for Porsche GT3 and Lambo etc for clearing speed humps. You might be able to get them to make you a custom kit but they're not cheap
You can then drop it back to normal or even a properly low ride for normal roads with the press of a button
https://www.kwsuspensions.net/produc...ic_lift_system
      10-23-2021, 08:04 AM   #4
M3AWD
M3AWD's Avatar
Drives: 2022 G80 M3 AWD
I agree an X3M, X4M, Stelvio, Macan, etc. fits your needs better. I can't imagine an M3 sitting higher than it already does. it'll look ridiculous unless it was a station wagon then it might work.
2022 G80 M3 Comp M xDrive
      10-23-2021, 08:07 AM   #5
barryc365
Drives: BMWM3
A Mitsubishi Evo or Subaru Impreza tarmac Rally spec sounds like it'd be a lot of fun on these roads and a lot less money and you wouldn't be worried about destroying a new car but I say go for it if that's what you want!! Would be a lot of fun if you don't care what the ride height looks like and the paint getting beat up from gravel
mlc5063.50
Limegrntaln13705.50
      10-23-2021, 08:12 AM   #6
modat
Drives: 2022 IOMG M3 Xdrive
Ripping a m3 on gravel? That gives me anxiety
      10-23-2021, 08:13 AM   #7
gotgemini2000
Never. Stick shift only.
      10-23-2021, 08:13 AM   #8
barryc365
Drives: BMWM3
Why not? It's his car. He can do what ever!
I wouldn't do it but that's not the point of the thread
Reminds me of this video…incredible!!!
      10-23-2021, 08:34 AM   #9
pikcachu
pikcachu's Avatar
1406
Drives: M235i (F22 Red angel)
I see no gravel though..
      10-23-2021, 06:08 PM   #10
CadHater
CadHater's Avatar
Germany
768
Drives: M3 Comp AWD
Ahhhh, a man of culture, I see.
par__m3452.50
      10-24-2021, 09:43 AM   #11
Salespunk
Drives: Slow
People here have obviously never seen the guy that posts under Lumber21 on IG
https://www.instagram.com/lumber21/?hl=en
GT2RS, GT3RS, AMG GTR, Ford GT, etc all get thrashed around his property in the woods. There is even a video from last Christmas of his GT3 with a Christmas tree tied to the rear wing while jamming around.
Personally I hope you rip it out there. If you think you really need to raise it then you will have to find an air ride kit. This will allow you to raise and lower the car on demand.
Grumpy514626.00
      10-24-2021, 09:54 AM   #12
moproblems
Beware of cheap bait!
moproblems's Avatar
712
Drives: 2021 M4 Isle of Man Green
Everyone thinking aftermarket when g20 base springs would probably be okay. It will more than likely be slightly overdamped but it should give you what you are looking for. If it doesn't work you are out a few bucks and 2 hours for install.
      10-25-2021, 06:45 AM   #13
gotgemini2000
So you think that the stock G20 3 Series Base Springs would raise the car a bit?
Beyond this - any suggestions on slightly bigger tires that can fit on 18 inch wheels (planning to get the base 18/19 wheel set, but know that even those need some more rubber near gravel etc.)?
Planning to order a G80 M3 in the next week or two if I can get a dealer allocation. Also need to figure out the roof rack / trailer hitch situation…
      10-25-2021, 10:25 AM   #14
moproblems
moproblems's Avatar
712
Trailer hitch will be very tough, as the muffler is so large there isn't any space for it. However a G20 kit will more than likely fit with some cutting of the diffuser and an aftermarket axle back.
And yes springs set the ride height and stock dampers already have plenty of downtravel. Before springs came out for m3/m4 shops were installing g20/g22 springs on em. However they will more than likely be WAY undersprung. Will not drive like it does at delivery and may have some undesirable characteristics.
[EDIT] I will also say barrel clearence on the front 18's is TIGHT. I only had mine on for 2k miles or so and I already had a good scratch in the barrel from a piece of gravel getting caught between the caliper and barrel... And I kept off the beaten path.
      10-26-2021, 08:20 AM   #15
ROBERT1183
ROBERT1183's Avatar
Drives: 2021 BMW M3 DRAVIT GREY 6SPEED
Im sure someone will eventually release an axle lift kit for the car. It will not be cheap though. I looked into doing the hydraulic kw kit on my F80 and it woulda been anywhere from $5-7k.
      10-26-2021, 08:34 AM   #16
par__m3
par__m3's Avatar
453
Drives: ‘22 G80 6MT
Don't really have anything to offer here but I just want to say that I think this idea is pretty badass. G80 M3 as a farm runner? I love it.
      10-26-2021, 11:42 AM   #17
Vic55
Vic55's Avatar
19798
Drives: 2023 BMW M8 Competition Coupe
Just get a G82 LOL
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
par__m3452.50
Mashour754.50
      10-30-2021, 01:26 AM   #18
mlc50
mlc50's Avatar
Drives: G80 M3 (6MT)
+1. Although a "rally" G80 sounds kinda badass definitely look into getting something like an STI.
I had one, changed the 19"s for 18"s and it was a badass little car and has decent ground clearance for stuff like this.
Only comes in stick (which you mentioned as a requirement) and AWD too.
Just sayin'.
'21 M3 Base - Brooklyn Grey
CA -> NJ
par__m3452.50
      10-30-2021, 07:04 AM   #19
flsupraguy
403
Drives: M5
X3m....
      11-05-2021, 10:57 PM   #20
gotgemini2000
Just sayin'.
No way. Working on an order (if I can get an allocation for a G80). Have zero interest in a WRX.
      11-05-2021, 10:58 PM   #21
gotgemini2000
Originally Posted by flsupraguy View Post
X3m....
Never - tall heavy roll-y. Want reasonably low and something I can rip around in. Plus need a 6 speed stick. If the X3M was a 6 speed maybe…
Sounds like best bet is G80, then get some G20 springs on it. Working on this…
      11-15-2021, 08:51 PM   #22
gotgemini2000
Ordered one. Any good rims/tires that would fit, and which get a bit more rubber and run at like an 18 rather than 19 or 20 that can be a bit better on dicey gravel>
g80
