11-25-2021, 12:45 PM | #1 |
Rep 271
NGK 97506 colder plugs
Are NGK 97506 1 step or 2 step colder plugs? Ecstuning says they are 1 step, burgermotorsports say 2 step. Or is it the gap the detemines how cold they are?
0.022 gap for stage 1 tune and 0.020 for stage 2? |
11-25-2021, 03:37 PM | #2 |
Rep 90
Compared to the S63tu they are the stock heat range. When they talk about 1 or 2 heat ranges colder they are referencing different BMW engines. 8 is the stock heat range in the OEM plugs and so are these.
2016 X5M DGM BM3 Stage 1 91
RK Autowerks Intake & RW Carbon parts |
11-27-2021, 03:27 PM | #3 |
Rep 1,066
Drives: 2015 X5 50i M Sport
0.024 to 0.028 (stock gap) for stage 1 and 0.022 for stage 2. I used 0.025 and no trouble at all. Tighter gap may create rougher idle especially when the engine is cold.
2019 Cayenne Turbo
11-27-2021, 08:39 PM | #5 |
Rep 1,024
The step colder has got nothing to do with the gapping. The tighter gapping is usually to account for higher boost, so you actually get a spark.
The temp rating to account for the actual temperature of the plugs/head so you don't get a premature detonation. Here is a brief view from NGK https://www.ngk.com/what-is-a-spark-plugs-heat-range-2 Last edited by Chilled; 11-27-2021 at 08:45 PM.. |
11-27-2021, 10:43 PM | #6 | |
Rep 1,233
Greeaaat...
Wondering if I'll want to go one stage cooler when I add my tune, based on the info I found by clicking around. Or it was mentioned that the plugs discussed here are in the same heat range? Will be bumping up to over 700hp at the crank with a Carbahn Stage I tune. Will I be okay with the plugs I installed? Thank you for the info! Last edited by Blue By You; 11-27-2021 at 11:41 PM.. |
11-28-2021, 02:05 AM | #7 |
Rep 1,024
I haven't done to much reading on tunes vs plugs for F85 and gapping vs cooler plugs.
It seams most guys that run a tune go for the cooler NGK 97506 and gap them to .022+/- or even down to .019. If i am not mistake the stock plugs are at .03+/-. I would guess, is if you are running a tune but your Engine/Cooling Temps are the same. If you have decent plugs (you do), All you would need to do is gap down your current plugs to .02ish. The question would be, is it the cooler plugs or tighter gap that make it run better? |
11-28-2021, 06:10 AM | #8 | ||
Rep 90
12-11-2021, 10:08 PM | #11 |
Rep 1,024
yep,
Also just FYI. you will need the thin walled socket. Regular will not fit. Last edited by Chilled; 12-11-2021 at 10:23 PM.. |
12-12-2021, 08:07 AM | #12 |
Rep 93
12-12-2021, 04:26 PM | #13 | |
Rep 1,340
https://www.amazon.com/dp/B0977LK9KS/ Or similar. Just search for 12 pt, 14mm thin walled spark plug socket. |
12-28-2021, 09:14 AM | #15 |
Rep 1
Just sharing my experience to the information already contained within this thread.
I purchased a Weistec tune for my 2017 X5 M. They advised I run NGK 97506 spark plugs and the gap they recommended was .022 to .024 inches. |
12-28-2021, 11:29 AM | #17 |
Lamininist
82
Rep 1,030
I agree, shouldn't need different plugs/gaps with a quality re-map and no other complicating factors, UK based tuners don't advocate this anyway.
Maybe it's a US thing with the comparatively lower pump fuel quality/higher sulphate content than what we have in Europe? |
12-28-2021, 11:46 AM | #18 | |
Rep 90
12-28-2021, 12:52 PM | #19 | ||
Rep 15
Carbahn: Nope Me: Is there anything I need to do other than install the tune? Carbahn: Well it's not just install a tune, but when you get the modified file back from us, all you need to do is flash it into your car, nothing else. You have the intake, right? Me: Yep Carbahn: Then yes, you don't need to do anything else, no plugs, nothing. It's simple. |
12-28-2021, 01:21 PM | #20 | |
Rep 1,233
Yup
12-28-2021, 11:45 PM | #21 |
-3
Rep 7
I still have no idea why guys are bothering with going with colder plugs on a pretty much stock setup. Overkill. I have 3 stage 2 S63 engines all with stock plugs. The only thing you might see is premature coil failure bc of the tune. Swap in replacement coils and be on your way.
Blue By You631.00 |
12-29-2021, 06:45 PM | #22 | |
Rep 90
