2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions How Can I Change Oil Service Intervals?
      11-28-2021, 04:42 PM   #1
HootisTigglebits
HootisTigglebits's Avatar
25
Drives: BMW M240i & BMW 330e
Arrow How Can I Change Oil Service Intervals?
I'm wanting to change the interval to 5,000 miles on my 2016 M235i, but apparently I'm not doing something right. I found a post in the F30 forum and have found the parts in green in e-sys.
Originally Posted by atzebmw
OK, i just have seen that there are different codings for different cars.
But first the coding for the Kombi which is the same for all cars:
KOMBI L7_MID > CBS_Konfiguration 3009 > CBS_WEG_FAKTOR_FZG_CHECK_DEPEND = faktor_5
KOMBI L7_MID > CBS_Konfiguration 3009 > CBS_ZEIT_FAKTOR_FZG_CHECK_DEPEND = faktor_4
Then there is a coding in the DME or DDE which depends on the engine i think.
Here i have 3 different BMW models as examples:
328i ----- DME > BSU-Config 3320 > OEL-Config = Wert_14
320D ----- DME__DDE7xx > OHNE_ZEITLIMIT 3701 > OWI_NEU = wert_11
335D ----- DME__DDE7xx > OHNE_ZEITLIMIT 3701 > OWI_NEU = wert_15
All these codings are for the 12TKM 12Month interval.
      12-15-2021, 08:24 PM   #2
BimmerDubs
Drives: M240I
I’m interested in how to do this as well (for a 2017 M240).
      12-18-2021, 06:46 AM   #3
ngl
ngl's Avatar
120
Drives: BMW 228i
When I coded mine, I changed the VO code that my car came with to 8KP ( 8000 km interval ) then coded defaults to DME and FEM_BODY.
This will change all values needed but you will lose custom FDL coding you had ( if you had any ) on FEM_BODY.
This needs to be done with engine off and a power supply ( you can't code DME with engine ON ).
Quaife LSD | BC Racing Coilovers | H&R ARB | F8x LCA+TS | Wiechers Strutbar | Mishimoto CAI | Mishimoto Oil Cooler | Mishimoto Oil Catch Can | Mishimoto FMIC | VRSF DP | Masata TIC | Masata CP | DV+ | Custom Kline Exhaust | GTS Style Roll Cage | Sparco Evo QRT | Brey-Krause seat mounts | Schroth Profi 2 ASM 6p | 10" Android HU| xHP Stage3 | BM3 | RaceCapture Data Logger | LithiumNext Battery
      03-24-2024, 06:00 AM   #4
DomasF
Drives: BMW F01, E83
I just made it working as needed. Below meaning of the wert. For oil interval change needed only to change one parameter.
DME
3701 OHNE_ZEITLIMIT
OWI_NEU
wert_1 78,64 - 30 tkm 24 m
wert_2 64,64 - 25 tkm 24 m
wert_3 60,4B - 24 tkm 18 m
wert_4 00,00 -
wert_5 30,64 - 12 tkm 24 m
wert_6 78,32 - 30 tkm 12 m
wert_7 64,32 - 25 tkm 12 m
wert_8 50,4B - 20 tkm 18 m
wert_9 3C,4B - 15 tkm 18 m
wert_10 3C,32 - 15 tkm 12 m
wert_11 30,32 - 12 tkm 12 m
wert_12 28,32 - 10 tkm 12 m
wert_13 20,32 - 8 tkm 12 m
wert_14 3C,64 - 15 tkm 24 m
      03-26-2024, 12:31 PM   #5
DS_BMW88
Sweden
21
Drives: BMW 218i Coupe
I just did something similar through VO coding (except for 15.000km interval, 1 yr). This is much easier with E-sys.
Be aware that you risk loosing your BMW service package subscription /guarantee if you have one!
2addicts
