12-11-2021, 10:25 PM | #1 |
Rep 44
Maintenance @200k miles
I finially hit the 200k mile point on my 2014 35D and actually have some time to do some necessary maintenance. The transmission pan/filter plus drain and fill was my biggest worry since I never tackled this before. There was quite a bit of metal shavings on the magnets but I guess this is to be expected at 200k miles. I went ahead and decided to change out both lower control arms as I started to have the infamous low speed noise/rattle which is actually still present after replacement, so I will change out both upper wishbones tomorrow. The lower control arm rubber bushings looked like they could have gone another 20k or 30k miles but 1 ball joint had some slight play. I also completed the routine oil and fuel filter change. Having completed all these maintenance items at one time definitely made a huge improvement.
2011 335D sport
2014 X5 35D m-sport 2014 X5 35I luxline |
7
The Libertine1237.00 scotty339147.00 P111591.50 PnP206.50 jmack1231302.00 Seattlesquash915.50 BlackBeans75.00 |
12-12-2021, 04:51 AM | #2 |
Rep 1,222
200K! Very impressive. But serves as testament to both the build quality of the F15, and your diligence in keeping up with the maintenance.
12-12-2021, 02:09 PM | #3 |
Rep 1,497
I was so hoping this was a 35i (N55), but kudos to you anyway. 200K on a diesel is just breaking it in right? lol
Which lower control arm did you replace? There's a lower forward and rearward arm. I had a hard time diagnosing my control arm clunk. Mine was more of clunk at very low speeds instead of a squeak like in this video, but the arm in the video was indeed my culprit. To bad that was literally the last arm I replaced lol. |
12-12-2021, 05:06 PM | #4 |
Rep 44
Yeah that's what I hear generally speaking about diesels we shall see lol. I feel the N55 can be just as reliable as long as one maintains it well and keeping the rpm down.
I replaced both lower forward and rearward arms(driver and passenger side). I completed the passenger upper wishbone minutes ago which is a royal pita. Driver side upper wishbone looks to be way easier(knock on wood), I'll find that out tomorrow.
2011 335D sport
12-12-2021, 08:08 PM | #6 |
Rep 44
As far as repairs go I've replaced the right tank fuel level sensor that was operational but had a delayed response and a Particulate Matter sensor(fault code).
2011 335D sport
12-13-2021, 12:11 PM | #7 | |
Rep 1,497
12-15-2021, 01:55 AM | #8 | |
Rep 5,022
Yeah I’ve been there with past BMWs. These days when things start to wear (typically 60-80k miles) I literally just buy everything for both sides. One and done and it handles like new. Kind of a pain to the wallet, but buy once, cry once! Glad you got it sorted! |
Surgx572.50 |
12-31-2021, 11:16 AM | #12 |
Rep 189
2018 with 57k now, hoping for smooth operation until 350k
Variante Alta95.50 |
12-31-2021, 12:35 PM | #13 |
Rep 10,314
01-01-2022, 01:11 PM | #14 |
Rep 552
My 2014 35d just hit 104k, and it suddenly has some nasty shakes under 1k revs. I have diagnosed everything from injectors, fuel, glow plugs, and even cleaned out all sensors, but all test come back in compliance and since there is no CEL I cannot pinpoint.
I checked the Harmonic Balancer and it is fine as well. I ran tests on my motor mounts via ISTA & pressures and they are activating the vacuum valve and holding pressures yet it is the same feeling so I do believe my mounts are shot. Gonna go in tomorrow and attempt changing them myself. I have everything I need, I just hope I can do it in less than 8 hours 🙄 |
01-09-2022, 05:22 PM | #16 |
Rep 35
Glad to see a high(er) mileage 35d, I have 114k on 14 35d hoping to get up and beyond 200k wouldn't trade it for anything currently on the market.
14 X5 35D. Carbon Black/ Cognac. M sport,469 M wheels, Bimmer tech Carplay, 20 percent ceramic tint, Factory solar windshield.
02-05-2022, 05:15 PM | #17 |
Rep 44
UPDATE: So after changing out both upper control arms in December I still had a front passenger suspension noise when going over road bumps and decided perhaps its failure of the passenger shock absorber. I went with the Bilstein B6 for a more sporty ride. After removing all stock shocks and testing them by compressing them down. I realized there wasn't much movement and waited for it to travel back up...here's what they looked like after 5 minutes of waiting. Yes 3 of 4 shocks where blown and the 4th(top) was traveling back up at a snail's pace I guess that's blown as well. Only one shock had visible leaking fluid covered by dirt/road grime I somehow missed during previous inspections. The rest were dry until you flip them upside down then fluid started dripping from the upper rubber cap. I will update my thoughts on how these ride after putting some miles on it.
2011 335D sport
02-06-2022, 06:16 AM | #18 |
Rep 270
Wow - it'll feel like a new car with those shocks replaced! My '15 35d has the M Adaptive Suspension option so a totally different set up I believe. Mine will be more costly to replace if / when it starts to go but I hope I'll get much longer out of the adaptive…time will tell. I'd like to get 300k miles at least out of the X5 (at 100k now and loving every minute driving it). Wishbones and control arms - well that'll be mandatory no doubt…appreciate the post and info.
02-11-2022, 03:25 PM | #20 | |
Rep 942
Drives: 2016 BMW X5
