bimmerpost/
BMW M2 and 2-Series Coupe
home
BMW 2 Series Technical Topics (G42) Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      02-13-2022, 11:36 PM   #1
zzyjason
Drives: G42
Oil change mileage?
When is the time I should change my oil? (First bmw owner)
Read somewhere the mileages that recommended from bmw are way too high etc etc
Currently at 4300miles
      02-13-2022, 11:54 PM   #2
TJZ67201
TJZ67201's Avatar
Drives: '23 M240i
This video answers a lot. Depends on how you drive and many other variables (frequent short trips, long time idling, etc). The car itself does a good job calculating your oil life based on idle time and other driving factors.
IMO, definitely would not wait for 10k miles. I drive hard anyways so I'm going to stick with about 5 - 6k mile intervals after break-in with high quality oil that meets BMW's spec. If you're just leasing or planning on trading in the next few years, then you can wait 10k miles…and just pass the long term issues onto the next owner(s) lol
zzyjason114.50
burkhacs126.00
      02-14-2022, 12:08 AM   #3
zzyjason
Drives: G42
Hahah. Thanks! Nah I don't drive it rough but I do want To take care of my car.
I probably doing 7k then.
      04-23-2022, 05:18 PM   #4
bobkat09
bobkat09's Avatar
152
Drives: 2023 M240i RWD
I do 5k miles. It might be a little bit of overkill but gives me peace of mind. And also easy to remember change intervals.
      05-28-2022, 03:16 PM   #5
allfitat55
Australia
121
Drives: 2022 M240i
2022 BMW M240i  [0.00]
I just got mine and Service is every 15,000Kms but the 1st oil change is at 30,000. Must be good bloody oil to last 30K The only other vechical that does 30K oil changes are my Prime mover truck I used drive for work pulling 68 Ton.
      05-28-2022, 04:03 PM   #6
danallxt
danallxt's Avatar
Drives: 2022 M240x, 2007 Honda VFR
Huh???you sure about that?
Oil change is part of the first service....at least here in the US.
      05-28-2022, 07:32 PM   #7
allfitat55
Australia
121
Drives: 2022 M240i
As per my app and on the idrive system
      05-29-2022, 03:33 PM   #8
Red_sir
Drives: 2022 M240i
Attachment 2895059
Interesting. I'm seeing something very different on my app in Canada. I certainly wouldn't wait until 30k km for the first oil change!
      05-29-2022, 06:26 PM   #9
allfitat55
Australia
121
Drives: 2022 M240i
Originally Posted by Red_sir View Post
Attachment 2895611
I normally do my changes every 5K (km) Will be interesting to see if the onboard computer changes the intervals depending on my driving style
      05-30-2022, 12:11 PM   #10
Dinosoar
Enthusiast
Dinosoar's Avatar
Drives: 2022 230i M Sport
2022 BMW 230i  [0.00]
Every 5K for me...AND, I am changing weight during Summer to 5-30, back to 0-20 for Winter. I'll end up having a climate change (LOL) standard than a mileage standard as I don't drive that much.
However, to answer your question...5K, IMO.
I just pulled out the factory oil at my first 5000-mile change and less than 5L came out! Other sources say over 5L, specifically 5.2L to 5.3L. Is BMW that cheap, or did my B48 burn off that much oil???
She's topped off now.
      05-31-2022, 01:58 PM   #11
allfitat55
Australia
121
Drives: 2022 M240i
I think I read a reply in a different thread to this problem that some oil stays in the engine and oil cooler even when you drain it. You never get rid of all it during a change.
Next time I would check the oil level before the change to see if it registering lower before draining
Dinosoar290.50
      06-04-2022, 05:42 AM   #12
dummyhalf
Australia
9
Drives: M240i (in transit)
Have you decided what oil you'll use for your changes?
Also curious to know what the Australian owner's manual states for oil weight.
      06-04-2022, 06:34 AM   #13
allfitat55
Australia
121
Drives: 2022 M240i
Not yet I will go to my normal guy and he will check it on his computer when its due.
      06-05-2022, 05:17 PM   #14
allfitat55
Australia
121
Drives: 2022 M240i
So according to the manual
Oil spec's are
BMW Longlife -12 FE or BMW long Life 17 FE+
SAE 0W-20
SAE 0W-30
Appreciate 4
g87
