03-23-2022, 02:39 AM | #1 |
391
Rep 202
Best Downpipe for M240i
Trying to work out what is the best Downpipe for an M240i G42
Are all F series B58 catalytic down pipes suitable for a G series? Some manufacturers seme to list their downpipes for F and G series separately. AA seems to be the only guaranteed to not through a CEL but Fabspeed also have a very high quality HJL which states it doesn't throw a CEL and is 100 cells less and uses a higher quality cat material then the AA, however fitment is only listed for F series Beemmers. |
03-28-2022, 02:44 PM | #5 | ||
513
Rep 357
That said, not sure how the various catted DPs stack up against stock for emissions. |
03-28-2022, 09:26 PM | #6 |
391
Rep 202
I received this from FabSpeed:
"Thank you for choosing Fabspeed, we sincerely appreciate your business! Your order is in process. Items that require fabrication have been scheduled in manufacturing, lead times will vary. Items that are in stock will be allocated, and if domestic delivery is indicated, will be partially shipped. " I suspect it needs to be fabricated, so may be a while. I've emailed for an ETA |
03-29-2022, 11:20 AM | #7 |
Rep 111
As far as I know, Fabspeed is the only licensed distributor for HJS cats in the US. So if you want the best performing cat that will also last the longest, they're #1.
03-30-2022, 06:04 AM | #8 |
Rep 13
I am wondering if I install an intake and down pipe would I need a tune ?
Just wondering the requirements for a tune with particular parts installed…. I’m a first time BMW Owner each of my other cars are different in requiring tunes for parts… I herd some b58 Supra owners are saying good things about the active auto works catted down-pipe Has anyone have good experience with this ? |
03-30-2022, 09:11 AM | #9 | |
Rep 480
04-01-2022, 05:56 AM | #10 | |
391
Rep 202
You don't need a tune to take advantage of the downpipe, the turbo will spool better once the DP is installed. If you do however apply a tune, you can run the turbo a little harder due to the reduced back pressure. |
