04-09-2022, 09:12 PM | #1 |
Rep 244
When will we see reviews of the M60?
I can't wait to see some reviews of the M60...and get some answers to some basic questions like...
- Is the extra power only available when using launch control? - Is the suspension the same as the xDrive50? - Is the range actually better on 22s compared to 21s (same as xDrive50)? |
04-09-2022, 09:23 PM | #2 | |
Rep 3,072
Drives: 2023 iX M60 Oxide
As far as power we have read that it will have 185ft-lbs more torque full time, and it pushes the peak HP down to be available about 1,000 RPMs earlier than the xDrive50. With boost mode it's another 62ft-lb of torque, but as you mention we don't know what steps are required to use that. The original press release references an "M specific suspension set-up". I hope Bjørn is able to get one and do some range tests. I suspect it will perform somewhat similar to the xDrive50, if the xDrive50 is similarly equipped (which would make it a bit heavier). They officially quote consumption of 23.0 – 19.8 kWh/100 km for the xDrive50 and 24.7 - 21.7 kWh/100 km for the M60, so there is some overlap there where they could possibly perform the same based on equipment , driving style, or conditions. |
04-09-2022, 09:49 PM | #3 |
Rep 1,826
Drives: BMW iX Xdrive40 MSport
Suspension is the same as that in the x50 with an M specific tune. The maximum 1100nm torque and 455kw power are only available for <10s when using launch control from standstill.
04-09-2022, 10:19 PM | #4 |
Rep 1,954
04-09-2022, 10:27 PM | #6 | |
Rep 244
That's kind of crazy if the extra power is only available when using launch control...not too concerned about the <10s thing as I don't see how often you floor a car as powerful as the iX for longer than 10secs anyway |
04-09-2022, 10:28 PM | #7 | |
Rep 3,072
ggalanis2452.50 |
04-09-2022, 10:33 PM | #8 | |
Rep 3,072
It's also not completely clear if the extra power is *only* available in launch control. The press release is a little vague and the reports interpreting the press release report it somewhat differently. If it didn't have so much torque full time I'd agree that it seems like a waste if you have to engage launch control for any difference. |
04-10-2022, 09:44 AM | #9 |
Rep 1,954
04-10-2022, 09:46 AM | #10 |
Rep 1,954
04-10-2022, 03:03 PM | #11 | |
Rep 3,072
https://www.press.bmwgroup.com/globa...new-bmw-ix-m60 |
ggalanis2452.50 |
