04-14-2022, 12:12 PM | #1 |
Rep 295
anyone considering removing rear badging from car?
I've considered removing the X drive and M240i badges of the back of the car.. my thinking is that it will just look cleaner... my car is Black Sapphire Metallic, with extended shadowline.. so having the chrome bits on the back might be distracting...
I know i've seen BMWs in my area that don't list the model on them... have others seen this? is there risk to the paint removing them? |
04-14-2022, 01:31 PM | #2 | |
Product Genius
97
Rep 162
beamer-dreamer226.00 Golddog566.50 |
04-14-2022, 04:00 PM | #3 |
Rep 1,959
I will likely remove the x-drive badge and get m240i in black.
Golddog566.50 Summeristooshort16.50 |
04-14-2022, 09:06 PM | #6 | |
Rep 63
2022 BMW M240i xDrive
2020 Alfa Romeo Guilia TI Sport (Sold) 2019 Audi RS3 FBO 2013 Ford Mustang Shelby GT500 2018 Subaru WRX 93 oct Stage 2 (Sold) 2009 Infiniti G37x Coupe FBO (Sold) |
04-14-2022, 09:08 PM | #7 | ||
Rep 63
04-15-2022, 05:29 AM | #9 |
Rep 426
I removed xdrive and did the oem black m240i
More pictures and the process here https://g42.bimmerpost.com/forums/sh....php?t=1898885
'22 M240i BSM, Shadowline, Black 791M wheels, Red Calipers, ///M Carbon Front Lip, ///M Carbon Spoiler, ///MCarbon Door Sills, Milltek Catback w/Black Tips, Dinan Carbon Intake/Engine Cover, AA Catted DP, Dalher Valve Controller, OEM+ Strut Bar, Red Start/Stop, Floating center caps, TLG Mud Flaps, Black Badges, Led Projectors, 50th Emblems, Carbon Diffuser/Mirrors w/smoke signals/Side Wings/Cooling Shroud/KIES fire extinguisher, Yellow DRL
04-15-2022, 09:35 AM | #10 |
567
Rep 300
Gonna remove the xdrive and keep the other, possibly changing it to black.
2021 Alfa Romeo Stelvio Veloce
2022 Chrysler Pacifica Touring L AWD (dog van) |
04-19-2022, 09:09 AM | #11 | |
Rep 78
Here are some pics! |
7
acouncilofone4.50 giolanzarin162.50 Waingrizzle3.00 Starsx3741.50 spansar51.50 gp_solo2190.50 MUFCbmwbear711.50 |
04-19-2022, 09:27 AM | #12 | |
Rep 251
That, and eventually getting the CF spoiler installed |
04-19-2022, 09:37 AM | #13 | |
Rep 78
Removed the 240i, took another step back.. "Alright, M has to go also" I LOVE the clean behind. I kept the fender ///M logos however, haven't decided if I want to remove those. I think they'll stay on. Definitely the way to go imo! |
04-19-2022, 10:18 AM | #14 |
Rep 69
I'm having the car tinted, PPF coated, and debadged before I even take it home. No one needs to know what's under the hood. Kind of...extra snobby in a non snobby way.
04-19-2022, 10:33 AM | #15 |
Rep 1,959
It's crazy that the only visual difference is the little trunk lid spoiler on the 240? 230 doesn't need that hood bulge, or big brakes (I sound like an M owner complaining that the 240 has M mirrors)
04-19-2022, 11:26 PM | #16 |
Rep 217
I removed the xdrive emblem. But I still have a very faint raised outline of the emblem. It is etched into the paint. Can't really see it looking casually, but if you look very close it is observable. I followed the proper process, but this was the out come. For anyone that has done this, is your emblem faintly observable up close?
04-20-2022, 05:57 AM | #17 | |
Rep 426
04-20-2022, 06:44 AM | #18 | |
Rep 1,959
04-20-2022, 08:48 AM | #19 | |
Rep 78
Care to share a pic? Might be able to help. Without seeing anything yet though, I suspect this is normal for now. There could be quite a bit of compound left behind when removing the emblem, and it could be tricky to remove it all properly. You start to walk a fine line of "am I going to damage my paint" while doing this, but you won't. My process after removing the emblem is: 1. Remove all excess compound by hand. Always pull away from glue (opposite direction from where it's peeling) 2. Spray some googone on whatever compound is left. You can also spray some on a microfiber cloth, and apply it onto the area for a few minutes. Once applied, rub the compound gently, but with pressure. Do this with the dry side of the microfiber cloth (to help loosen the compound), once you see it start to move around, use the wet side again to help wipe off. 3. Once clear of glue. Get dry cleaning spray, apply it to area that had compound/googone and clean thoroughly. Hopefully that helps! |
04-20-2022, 09:23 AM | #21 |
Rep 78
4
04-20-2022, 10:01 AM | #22 |
567
Rep 300
Lord Two Hats96.50 |
