05-25-2022, 12:20 AM | #1 |
Rep 1,832
Drives: BMW iX Xdrive40 MSport
BMW Wallbox Gen 3 Unboxing
Featured on BIMMERPOST.com
Current: iX Xdrive40 | MSport | 22" Bicolour | Amido Interior | Mineral White Metallic Last edited by hugo_nz; 05-25-2022 at 12:39 AM.. |
05-25-2022, 12:39 AM | #2 |
Rep 748
Oh yes please! Maybe push it to YouTube as there is virtually no Gen 3 wallbox videos on there.
BMW iX M60, Storm Bay with XPEL Stealth PPF, Exterior Line Titan Bronze, 1EW 22" 1023 Wheels, Amido Leather, Comfort Package, Interior Camera, Clear&Bold, Sun Protection Glazing, B&W Diamond Sound, Folding Towbar, Rear Axle Steering.
05-25-2022, 12:42 AM | #3 | |
Rep 1,832
Current: iX Xdrive40 | MSport | 22" Bicolour | Amido Interior | Mineral White Metallic |
05-25-2022, 12:45 AM | #4 |
Rep 748
Awesome, thanks for sharing this. The metallic looking blue charge cable is nice!
These BMW Wallbox chargers are pretty cool in that they support single phase and 3 phase in the same unit.
05-25-2022, 12:50 AM | #5 |
Rep 1,832
The install instructions are crazy. And it has smartphone connectivity too (through bluetooth I believe.
05-25-2022, 04:51 PM | #6 |
Rep 1,832
Here's a slightly more detailed look
05-25-2022, 05:22 PM | #7 |
Luxury at the redline :)
9108
Rep 7,563
Cool, BMW offers a 120V option.. Meaning you can you use a standard household power outlet without upgrading the wiring or circuit breaker to charge your vehicle..
240V fast charging is also available if your home wiring and electrical panel can handle the upgrade. Some older homes would require new wiring and possible recertification to implement this option. . |
05-25-2022, 05:27 PM | #8 | |
Rep 4,536
Drives: 2022 iX xDrive50, DGM
4
05-25-2022, 05:43 PM | #9 | ||
9108
Rep 7,563
You can write off some of the expense to install a wall outlet on your federal taxes (some states also) but it depends on the year and the incentive/rebates available for that specific time period. Not sure about BMW but Tesla even covers a substantial portion of the cost of installation if you list your charging station as "public." But that sounds like a horrible idea for a home unit, unless it's on a business premise and offering recharging is absorbed as incentive to your customers. . |
Paladin15628.00 QuarterMileJoe9.00 |
05-25-2022, 06:53 PM | #10 |
Rep 1,649
Your local electric utility may offer a rebate for installation too. Check. Ours gave us $500 towards the actual charger and $500 towards install. Both were a rebate to submit after but it only took two weeks to get a check.
05-25-2022, 09:45 PM | #11 | ||
Rep 3,456
Drives: Harrop E90 M3
3.6kw max, realistically more like 3-3.2 through level 1 (110v). If you're charging an iX with one of those divide that into 105Ah battery to get your charging time. iX/i4 are coming with the new flex charger that is better, especially on 220v compared to the previous turbo cord. In that case all owners would need is the correct Nema 14-50R outlet in their garage (with a 50A circuit ideally) to connect and charge more efficiently. |
05-26-2022, 01:11 AM | #13 |
Rep 1,832
05-26-2022, 06:32 AM | #14 |
Rep 32
05-26-2022, 06:37 AM | #15 |
Rep 748
Yeah it’s a BMW NZ promotion for all electric vehicles sold until 1 Jun 2022 I think.
05-26-2022, 08:03 AM | #16 | |
Rep 1,987
The most continuous amperage you should draw on them are 16A or 12A. This means that you can expect to pull from 1.4 to 1.9 kW max on a LVL 1 charger. |
BimmerBahn441.00 |
05-26-2022, 01:25 PM | #17 |
Rep 1,832
I wired the Wallbox up to an industrial plug using 6mm 32a capable wire to connect to our 32a single phase industrial socket at home. Initialised the Wallbox and updated the firmware, and the app shows full 32a available for charging. I’ll report back on charging performance once I get my IX.
07-05-2022, 09:37 AM | #20 |
Rep 4,536
07-05-2022, 11:35 AM | #21 |
Rep 86
I was advised by the BMW Genius that max power output for Gen 2 is 11kW while Gen 3 goes up to 22kW. Unfortunately, I am not able to find anything online to confirm this.
Even if that is the case, it might not make any difference for the iX as it is fitted with a Type 2 AC 11kW on-board charger. Nevertheless, the Gen 3 (with 22kW?) will be a better future-proof charger to have as well as if you have other EV that has a higher on-board charger. |
07-05-2022, 02:03 PM | #22 | |
Rep 2
I have gen. 2 an it can charge also 22, so it should be just new design. I was just wondering if it doesn’t come with some feature like app for phone or ability to charge from photovoltaic panels etc…
Thanks! Quote:
