06-06-2022, 03:21 PM | #1 |
Rep 29
G42 M240i 1st to 2nd shifting issue?
Hello Everyone,
Just got a G42 M240i a month ago and its an awesome car! I noticed when Im in manual mode and I go WOT in first gear and I go to shift at 6500rpm the whole car shakes violently. At first I thought I was hitting rev limiter while the shift was happening but then tested it out and rev limiter is at 7000rpm. This issue only happens in first gear. If I shift 1st @ 6000 rpm this doesn't happen. If the transmission is in sport/auto mode it will shift itself in 1st gear at 6000 rpm and won't let it go higher. Every other gear will go higher without issues. I remember my previous M240i with the ZF 8 speed has something similar happen in first gear but not nearly as bad of a shake just like a little delay. Anybody else experiencing this? Thanks for any input or help! -Theo |
06-07-2022, 09:32 AM | #4 |
Rep 179
I have almost 2k on mine no issues this may sound stupid but try taking of the safety features lane assist and stuff a see if it still does it
06-07-2022, 10:10 AM | #5 | |
Rep 187
I'd try purposefully hitting the limiter once and see if it's the same feeling. |
06-07-2022, 12:35 PM | #6 | |
Rep 29
tubingchamp102.50 |
06-13-2022, 04:50 PM | #9 |
Rep 29
Hey Everyone,
I have an update for you, that feeling I was getting was wheel hop, would happen in sport+ and more so when traction control was turned off. It was happening when the weather was cold. Took it to the dealership today, was a hotter day but it wouldnt do it, then I took traction control off and it did it so im glad its nothing more than that! Appreciate everyones help and input! Cheers Everyone! |
Tags |
1st gear, first gear, rough shift, shifting rough |
