07-01-2022, 03:28 PM | #1 |
Rep 4,539
Drives: 2022 iX xDrive50, DGM
USB Storage
Just a sampling of USB-C drives - nothing yet as compact as SanDisk's Ultra fit drives, but maybe on the way. The USB-C storage devices tend to be (as of now) larger, usually dual-port format, and smaller in memory size (32-128GB). USB-C has been around for awhile, so not sure why the delay but perhaps because it started as mostly a mobile phone connector. Any should fit in the front USB slots of the iX though, even if slightly intrusive, and adequate for most storage needs.
* Scratch the SanDisk - that's a micro/A, but they do make a larger C stick. Last edited by Paladin1; 07-01-2022 at 03:39 PM.. |
07-01-2022, 04:24 PM | #2 |
Rep 3,078
Drives: 2023 iX M60 Oxide
From what I understand, the USB A drives cheat by putting some of the PCB and electronics into the rather large connector. That's not really possible on the USB C, so they end up being larger.
They can literally just package up some Flash memory and put USB A contacts on the back and it fits. |
07-01-2022, 04:29 PM | #3 | |
Rep 4,539
07-01-2022, 04:33 PM | #4 |
Rep 3,078
Yeah that one is an interesting design, not as stealth as in the connector but at least it is totally flat. I wonder if it risks blocking adjacent ports in some situations. You'd think they could double it up for higher capacity.
07-01-2022, 05:00 PM | #5 |
Rep 4,539
Gonna find out in a month or so I hope (depends on the space between USB ports)! Works dandy in my X5....
07-01-2022, 08:09 PM | #6 |
Rep 169
I have this 256GB Samsung backordered on Amazon. Looks pretty compact.
Since there are no concealed USB ports in the car, which would be the "safest" port to use to avoid theft of the drive ? |
07-02-2022, 02:03 AM | #7 |
Rep 109
I am guessing you are planning to store music/media on a USB device for playback in the car? I would always recommend getting a full-fledged portable SSD instead of a flash drive for this purpose as flash drives have a very limited endurance (the amount that can be read and written to them). They generally fail within a couple of years of moderate use.
Given that some of the features on the iX can write to external media, like Drive Recorder, this can exacerbate the limited life on these drives. The last thing I would want is the drive to fail on me when I need it for evidence during an accident. |
07-02-2022, 08:58 AM | #8 | |
Rep 4,539
slampert162.00 UltimateMoneyShifter97.50 |
07-02-2022, 09:09 AM | #9 |
Rep 4,539
With no console port, I'm not sure that there is a "hidden" port you can use, but the USB ports by the 12v are pretty low and not immediately visible. Tinted windows would help, but actually someone breaking into my car and stealing my $20 USB drive would the least of my concerns in the event of a break in. As far as I know, these are the only two data ports in the iX, unfortunately.
slampert162.00 |
