09-09-2022, 09:06 PM | #1 |
Rep 26
JB4 map 2 or 3?
As the title says. I will be running shell 93 that has 10%E, dinan intake, Dp and thinking muff delete with some resonators. I'm thinking map 3 should be fine and 2 would be extra safe. Any opinions welcome
09-10-2022, 08:21 AM | #2 |
391
Rep 202
With a DP try the Alpha software and Map 6 - absolutely PSI target of 22
You'll likely find Map 2 or map 3 causes a very brief timing pull around 2,800rpm which causes the car to momentarily surge under max throttle. |
09-10-2022, 10:07 AM | #3 |
Joint Chiefs of Staff
24199
Rep 190,807
Per BMS, do not use additive maps on the new chassis. Use absolute maps instead.
i recommend you use map 5
11-02-2022, 06:03 PM | #4 | |
2063
Rep 1,559
Map5: Absolute target map with peak target of 22psi (30% E85+ fuel, EWG connector suggested) |
11-03-2022, 08:54 AM | #5 | |
24199
Rep 190,807
The significant difference between the two chassis is the stock boost. G chassis applications run a much higher boost. Back to the recommendation Running map 5, 22 PSI on the F chassis is a considerable PSI increase. You should only do it if you are running an E85 mix. Running map 5, 22 PSI on the G chassis is not adding much since the stock application can reach up to 20 PSI on its own in optimal conditions. Correction: If you are not mixing with E85, start with map4. For a clean log, map5, in most cases, will require some mix of E85. No matter which map you run, send the datalog to BMS for map approval.
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 11-03-2022 at 03:50 PM.. |
4
11-03-2022, 09:09 AM | #6 | |
2063
Rep 1,559
11-03-2022, 03:51 PM | #7 |
24199
Rep 190,807
That's why I'm here
11-03-2022, 04:11 PM | #8 |
Rep 751
Taking into account the the G platforms are already pushing 20psi it makes sense that running map 2 or 3 with a JB4 is asking for trouble pushing 24/26 psi.
I'm only looking for a slight boost increase without bolt ons and would be happy with a max 22psi. I'm looking at a JB+ but turning it down from the standard 3 o'clock position to 12 o'clock which will be around 2 psi so 22psi total. |
Alpine Flyer138.00 |
11-03-2022, 05:08 PM | #9 | |
2063
Rep 1,559
Also keep in mind the B58 is now a closed deck, and I really doubt BMW carried over the same turbo from the F series. Point being this isn't the same B58 as day 1 with just more factory boost. |
335i E92176.50 |
11-03-2022, 05:25 PM | #10 | ||
Rep 751
I'll go with the Jb+ at halfway setting, K&N panel filter and 99 octane fuel 'UK'. Should be safe enough! |
11-03-2022, 05:37 PM | #11 | |
2063
Rep 1,559
I order the AA DP today and will try it out with the JB+ (default position), and then eventually trade-in the JB+ for the JB4. I wanted to try each of the 3 mods one at a time to get a feel for their individual contribution. |
11-04-2022, 08:47 AM | #12 |
24199
Rep 190,807
11-05-2022, 12:48 PM | #13 |
Rep 706
excellent , be sure to report back here on your findings.
11-06-2022, 09:38 AM | #14 |
393
Rep 320
Remember, when it comes to octane ratings, the UK and US use different measurement systems. The US uses AKI (aka (R+M)/2) to come to the figures like 87, 91, and 93 octane. The UK uses RON. So, 99 RON is technically the same as 93 AKI octane here in the States.
11-06-2022, 10:45 AM | #15 | |
Rep 751
My point was that with the JB+ in halfway setting which is circa +2psi, it should be safe enough to run with UK 99 octane and wouldn't boost higher than the 22psi ceiling in some of the safer JB4 maps. |
M240SLC392.50 |
11-06-2022, 11:55 AM | #16 | |
393
Rep 320
11-06-2022, 12:41 PM | #17 | |
2063
Rep 1,559
11-06-2022, 04:13 PM | #18 | ||
24199
Rep 190,807
Please review my post again. If you are running 93 on the new chassis, you need to start with map 4 , datalog, then map 5 and datalog. Quote:
11-06-2022, 05:55 PM | #19 | |
2063
Rep 1,559
Below is my recent chat with BMS and I made it clear I have the new chassis and an otherwise stock car with plans to order a DP (delivered today - THANK YOU FOR THE GREAT SERVICE! ). If 4 PSI is not safe with 91/93 on the G chassis, BMS has said nothing to suggest otherwise on their JB+ page where the G chassis is not only listed, but shipped in the 4 PSI default position (3 o'clock). Something else that causes me a little confusion is if our cars hit 20 PSI in optimum conditions while stock, and the JB4 on Map 5 only offers 22 PSI, and only 20 PSI on Map 4, then why bother spending $530 - $680 on a max gain of 2 PSI? |
Sonic RR118.50 |
11-06-2022, 06:10 PM | #20 | ||||
24199
Rep 190,807
As for the last question , please remember 20 psi is in optimal conditions and only during a short rpm range. In most cases the car will be running below 20 ( my stock m4 should be running 25 psi stock , during the summer it was running 18 psi) When you set the jb4 at 20 or 22 , now the car will target this psi under all conditions and for most of your rpm range . It's a big difference between stock and the mildest Jb4 map, making it well worth the $529
Sonic RR118.50 |
11-07-2022, 02:36 AM | #21 | ||
Rep 281
Despite what BMS says, people have blown their turbos when running the more aggressive additive options. Not to knock them, but I have seen them advise some of the Supra guys to run JB4 map 3 only for disaster to result. Mike's advice on the other hand seems to be spot-on. Definitely would be the safer way to go.
2022 G42 M240i xDrive TM/TR
Past: 2019 F32 430i MG, 2015 F30 328i AW |
11-07-2022, 06:28 AM | #22 | |
2063
Rep 1,559
Once I go the JB4 route I'll likely skip the Maps 1-3 and leave it on Map 4 with logs sent to BMS as Mike suggests. |
