bimmerpost/
BMW M2 and 2-Series Coupe
home
BMW 2 Series Technical Topics (G42) Suspension / Brakes / Chassis
      10-11-2022, 10:49 AM   #1
oldbmwtech
oldbmwtech's Avatar
193
Drives: BMW M240i
Camber Plates
Does anyone make front camber plates for the G42?
This is only my opinion as I'm a retired professional ASE master grease monkey technician, now instructor. Your best teacher is your last mistake. Use what I post at your own risk as you know teachers only know book knowledge.
      10-13-2022, 11:44 AM   #2
oldbmwtech
oldbmwtech's Avatar
193
Drives: BMW M240i
For those that need these Vorshlag has them
      11-08-2022, 10:15 AM   #3
oldbmwtech
oldbmwtech's Avatar
193
Drives: BMW M240i
I have installed the Vorshlag camber plates and worked out very well. The max neg. camber is approx. -3 degrees. If anyone does this it is highly advised to replace all suspension bolts removed since they are torque to yield bolts.
      12-05-2022, 04:49 PM   #4
kkgriss
Drives: 2022 M240i
Do you have recommended alignment specs-Track vs. street?
      12-08-2022, 07:52 AM   #5
oldbmwtech
oldbmwtech's Avatar
193
Drives: BMW M240i
With these camber plates I can get about -2.5 to -3 degrees camber and I would set toe at 0 or just a bit positive toe for track set up. This is what I run on the track for street -.5 camber and 0 toe or a bit negative toe. These camber plates are very easy to adjust. For adjusting toe I use Longacres toe plates and adjust each tie rod equally. I have read other toe plates use very thin metal and bend easy so I stayed away from them.
      12-09-2022, 03:45 PM   #6
kkgriss
Drives: 2022 M240i
Excellent! Thanks so much for sharing your specs. Nice recommendation on the toe plates as well.
g87
