10-17-2022, 11:31 AM | #1 |
Rep 643
What cambers are you running?
Hey guys, I am frustrated with Michelin CUP2. I'm the recent last three front sets of cup2 on my M4, they all got shredded after 1 -2 days of track. In the most recent event, my front camber it's at -3.3. Same shit happened again. I had to clock out after finishing session 3.
Is anyone else have this problems with Cup2? I have a set of Nankang CR1 ready for the next track day. I will see what the difference are.
2021 M4 Competition
2020 M340i |
10-17-2022, 11:46 AM | #2 |
Όλα ρόδες
760
Rep 560
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
If your camber up front is -3.3 and you tires look like this, either your tire pressures are low or it's just inevitable given the car's weight.
10-17-2022, 12:02 PM | #3 |
Rep 655
what rear aero do you have?
camber i am running: https://g80.bimmerpost.com/forums/sh...php?p=28922601 |
10-17-2022, 02:21 PM | #4 |
Rep 643
Hot tire pressure it's at 32psi on the track. I'm going to try -3.6 and Nankang CR1 next event to see the difference.
2021 M4 Competition
2020 M340i |
10-17-2022, 02:38 PM | #5 | |
Rep 643
2021 M4 Competition
2020 M340i |
10-17-2022, 03:06 PM | #6 |
Rep 655
10-17-2022, 03:18 PM | #7 | |
Rep 643
I asked about the G82 M4 GT4 wing. They want 8k. I gave up. I can put those $$$ for tires.
2021 M4 Competition
2020 M340i |
dirtyfreebooter340.50 |
10-17-2022, 08:53 PM | #8 |
Beware of cheap bait!
709
Rep 715
I consider chunking atypical wear. Get off of cup2 and run something that can take heat better, or take more cool downs.
Also I believe the on the money hot pressure is 36psi front and rear for these on cup 2 connect. |
10-17-2022, 11:57 PM | #9 | |
Rep 92
gnx759.50 |
10-21-2022, 09:21 AM | #10 | |
Rep 924
Edit: ok I see you have the spl lower bits all over and coilovers. Camber adjustment is based on tire temps. You want even temps across the tire in the hot pit after two flying laps. Perhaps you're overdriving the tires.
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10 |
