11-03-2022, 10:38 PM | #1 |
Rep 3
Oil type and oil capacity??
Hey guys i have recently picked up a 2023 M240i and loving it. I understand that a 2k mile oil change might not be necessary but I plan on doing it anyways to cast away my internal thoughts of metal shavings from "break in" period. Anyways with that being said, what oil and how much of it should I be putting into the motor? I really cant find much on this new platform i think I ended up finding that Castrol edge euro spec would work because it says BMW LL01 on it?
11-04-2022, 02:47 AM | #2 | |
Rep 428
M240i x-drive (Thundernight, 19" 893Ms, Cognac, Pro Pack, Adaptive, Sunroof)
inc235116.50 |
11-04-2022, 05:09 PM | #3 |
Rep 3
They're not in the manual, it only says that it has to be BMW LL17FE+ and I cant find that type of oil anywhere on the internet or auto stores. Also no where in the owners manual says if LL01 is okay or how much oil to put in. But thanks for your shitty advice of letting me know that I should look in the owners manual because you think its in there.
11-04-2022, 06:03 PM | #4 | |
Rep 177
As far as brands I’m going with Castrol Euro formula or BMW brand oil. Oil capacity is 7 quarts or 6.5 liters I also do 5k mile intervals BTW, I just read a post on someone who did a 2k mile oil analysis and found no metal shavings. Last edited by bobkat09; 11-04-2022 at 06:40 PM.. |
11-05-2022, 03:12 AM | #5 | |
Rep 122
BMW LL-12FE, LL-17FE+ Oil spec API SL, SM, or SN. 0W-20 or 0W-30. Since 2021, BMW OEM engine oil is back to Castrol in case you are wondering.
Current: 2023 G42 M240i, w/ ZTK
Past: 2016 F22 M235xi |
Invisiblename352.50 Caerus531.50 |
11-05-2022, 03:14 AM | #6 | ||
Rep 428
11-05-2022, 03:26 AM | #7 | |
Rep 428
11-05-2022, 12:39 PM | #8 |
Rep 706
Note the US spec for oil is different
attached is from US 2022 m240x only 0-20 viscosity is referenced only LL-14FE and 17FE spec is referenced, other than 1 quart of other common spec for top off if the above cannot be found. (US spec likely different due to need to meet CAFE fuel mileage?) |
Invisiblename352.50 |
11-05-2022, 07:07 PM | #10 |
Rep 428
It's been said elsewhere that the oil capacity is VIN specific & that you need to ask your dealer to read it off their system
11-06-2022, 12:45 PM | #11 | |
Rep 706
OR ya may have to have an auto parts store order it. there is BMW branded oil that meets the spec there is Castrol edge 0-20 that meets the spec (be careful here, not all Castrol edge 0-20 meets the LL-14FE or 17Fe specs, lots of different Castrol versions. Motul also makes a 0-20 LL-14Fe. You will find these spec oils a bit costly. that is if you want to keep with BMW spec....me i just used some old drain oil i had laying around. |
11-06-2022, 05:06 PM | #13 |
Rep 706
11-15-2022, 03:29 AM | #14 | ||
Rep 122
My post #5, is the downloadable manual from Driver's Guide App (US spec 2023 m240i). Note Oil Specs in API standard, not ACEA specs. It lists 0W-30 as suitable grade, in addition to 0W-20, and also NO Longer notes LL-14FE, but rather LL-12FE as the replacement. I haven't checked paper copy that came with the car to confirm same info, but interesting change nonetheless.
Past: 2016 F22 M235xi Last edited by inc235; 11-15-2022 at 03:36 AM.. Reason: typo |
11-15-2022, 03:32 AM | #15 | |
Rep 122
6.5-7.2L seems to be the capacity, but you can buy 8Qt, see how much drains, then refill same amount.
11-15-2022, 02:54 PM | #17 | |
2063
Rep 1,559
11-15-2022, 03:01 PM | #18 | |
2063
Rep 1,559
11-15-2022, 03:04 PM | #19 | |
2063
Rep 1,559
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 and 1 of these... https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 and you're set for 7,000 miles. |
11-15-2022, 08:14 PM | #20 | |
Rep 122
Now you can say to them LOL. Quick search on BMW LL-12FE returns 0W-30 as well. LL-17FE+ is 0W-20 though.
XC3LLR82062.50 |
11-16-2022, 03:16 PM | #21 |
Rep 751
