01-28-2023, 02:16 PM | #1 |
Rep 161
BMW 530e Battery - Turn off all current
I'm looking to do a heated wheel retrofit on my 530e and when I disconnected the primary battery on the passenger side, the car was still "alive"...
Obviously, I was quite surprised as in my F30 330e and every other car, disconnecting terminals kills the current. Is there another location I need to disconnect?? |
02-02-2023, 04:14 PM | #2 |
Rep 1
Yes, I learned today that there is an auxiliary battery under the trunk floor. Sadly, I have to replace mine as I bought the car as a CPO and batteries are not covered.
05-08-2023, 01:30 PM | #3 | |
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
05-08-2023, 07:52 PM | #4 |
Rep 161
Yes. You need to disconnect the battery in the center of the trunk, not the side. You need to remove the pins for the flooring underneath the trunk bottom that goes up and down. 4 plastic push pins. Then just remove the floor trim. Then disconnect battery. Car goes dead after a couple of seconds.
I did this to replace my steering wheel. |
Volasko705.00 |
05-09-2023, 09:04 AM | #5 | |
Rep 2,605
