BMW M3 and M4 - The Icons
home
G80 BMW M3 and M4 General Topics Regional Forums USA - California
      02-23-2023, 07:58 PM   #1
myg80m3
myg80m3's Avatar
1135
Drives: BMW G80
Enjoy The Shoot Manual G80
Did a photo shoot Sunday
My White G80 M3 Manual Fall-Line front traction arm spherical bushings, SPL Rear traction Arms, SPL Rear Toe link and Essential Lockout kit, KW Has kit with 15mm rear KW spacer, BMC drop-in filters, H&R 12mm Spacers all around, MHC front lip, Turner duckbill. Should have all the SPL Arms replaced soon. I do all the work myself.
m4ml1834.00
      02-23-2023, 08:01 PM   #2
myg80m3
myg80m3's Avatar
1135
Drives: BMW G80
      02-23-2023, 08:04 PM   #3
myg80m3
myg80m3's Avatar
1135
Drives: BMW G80
JDUNITNOW3513.00
Nkr151123.50
      02-23-2023, 10:34 PM   #4
fanofbmwe46
Drives: M3
Absolutely perfect. Looks amazing.
      02-24-2023, 02:32 PM   #5
myg80m3
myg80m3's Avatar
1135
Drives: BMW G80
Thank you so much
      02-24-2023, 07:25 PM   #6
m4ml
Drives: 2022 M4CX BSM (Xpel Stealth)
Have the SPL additions improved road feel? There are only two things that I liked more about my F82 (with Dinan coilovers and trailing arms) than my G82. One was the sound system and the other was the handling. With the Dinan suspension the F82 felt much more connected with better response. The G82 feels more "elegant" and disconnected.
I'm getting the Fall Line monoballs put on in a couple weeks, I've read that that alone improves the feel. But, I'm skeptical that it will give me what I want.
With all of that said, I've considered the SPL hardware if I still feel lacking in the feel department after the monoball upgrade. What are your thoughts on the SPL hardware so far? It sounds like you're doing a couple upgrades at a time, so I'd be anxious to hear about your experiences as you add more hardware.
Perf: Carbahn Stage 2, Eventuri Intake, PSI Midpipe, Remus Race Exh
Susp: Turner Skid Plate/Strut Brace, KW v4, F-L Monoball, MS: Camber Plates, Spacers, SPL Rear
Cosmetic: MPerf: Splitter, Side Vents, Sill Plates, Door Projectors; IND CF Roundels/Float Center Caps, Vorsteiner Grill, Xpel: Stealth PPF, Fusion Plus Ceramic, XR Plus 5/20/70
      02-24-2023, 07:49 PM   #7
myg80m3
myg80m3's Avatar
1135
Drives: BMW G80
With the Fall-Line monoballs alone you’ll definitely a big difference with feedback. The steering feels a lot tighter. I love it. The SPL arms also helped with the overall feedback and stability. My cars much tighter all around under braking and cornering. Feels a lot more stable. Definitely recommend it.
I did all the work myself and make sure whom ever does the Fall-line front spherical bushing for the front traction does proper work. They would need to completely disassemble the front bumper, air ducts ,braces and a lot of brackets just to get to the bolts that mount to the inner part of the chassis.
      02-25-2023, 02:41 AM   #8
m4ml
Thanks for the insights. I'm really hoping the monoball brings some life into the feel.
kevin @ eas EAS is doing the install. I'm re-doing the grills and adding a lower rock guard at the same time, so the bumper has to come off no matter what.
      02-25-2023, 10:58 AM   #9
myg80m3
myg80m3's Avatar
1135
Drives: BMW G80
You’ll definitely be happy with the results
m4ml1834.00
g80
