03-12-2023, 03:35 PM | #1 |
Rep 451
Drives: 2022 BMW M240i
Break-in period question
Hey,
So I recently bought a 2022 M240i with only 500 some miles on it. It was a fleet vehicle for shows and is now a year old (first titled in February 2022 to BMW of North America). Am I correct to assume that even though the car is a year old, as far as the engine is concerned, it has not been properly broken in since it's under 1200 miles still? (at 810 miles currently). I am asking in terms of pushing the car before it hits 1200. Cheers. |
03-12-2023, 03:46 PM | #2 |
Rep 507
Who really knows how the car was driven if it was a fleet/company/demo car. Could have just sat at shows or was thrashed by drives and execs. It would be safest to get an oil change since it’s already been 1 year, then follow standard break in procedure until 1200 miles as stated in the owners manual.
2017 Chevrolet Corvette
2023 BMW M240i xDrive |
4
03-12-2023, 05:22 PM | #3 |
Rep 2,070
Or you could take the approach of a Swedish, Nordic rallying friend of mine whose view is, forget the running in, drive it as you want to use it from day 1.
To be fair, a 150mph + vehicle with an automatic gear box (and computer limited shifting) is highly unlikely to break. All that said, I’d follow the advice from Coconut |
viperx100627.50 |
03-12-2023, 06:17 PM | #4 |
Rep 451
Haha, I am almost there anyway. I drive with hand controls and they are getting installed this weekend, so I can just take it easy and get used to them in the meantime.
XC3LLR82062.50 |
03-14-2023, 08:56 AM | #6 | |
Rep 124
If BMW didn't change it, suggest you change it and continue the break-in until 1200 miles in case it was well taken care of for the first 500 miles. If it was driven hard for the first 500, getting that oil and filter out now is probably a good idea. |
viperx100627.50 |
03-14-2023, 09:41 AM | #7 | |
Rep 451
03-14-2023, 01:04 PM | #8 |
Rep 706
Yes,any BMW dealer service dept should be able to tell if its had its annual change. If it hasn't i would definitely change it, not because it may have been driven hard, actually the opposite, if it had a lot of short drives (lilkely with the low mileage) say less than 15 miles at a time, which really does not get the oil heated enough to burn off the moisture, etc that can accumulate, is far worse. (This is why BMW specs an annual change regardless of low mileage).
03-14-2023, 01:47 PM | #9 |
Rep 451
Not to mention that the annual service is included for free for the first 3 years. I would get it no matter what, but why not take advantage of the deal?
03-14-2023, 03:11 PM | #10 |
Rep 706
Just to elaborate a bit on short trips and oil contamination. The combustion process itself produces water vapor, which can condense with short trips (not burnt off), that water can combine with sulfur (also a byproduct of combustion) to form a sufurous acid....which in turns tends to break down oil. There are other combustion by products as well. Fuel, water and acids not burnt off contribute to the dreaded sludge you find in engines that are driven short distances and with infrequent oil changes.
4
03-14-2023, 03:35 PM | #11 | |
Rep 451
06-20-2023, 11:13 PM | #12 |
Neophyte
110
Rep 54
Drives: 2023 BMW M240i xDrive
Garage List 2023 BMW M240i xDrive [10.00]
2007 Aprilia RSV 10 ... [0.00] 2013 MV Agusta F3 [0.00] 2007 Acura MDX [0.00] |
For many years now I've adopted the hard break-in theory to get the rings seated and expose those internal to the "real world" pressures and speeds that actual (spirited) driving will produce. Maybe there is another thread buried from many years ago where this topic was hashed out to the n'th but I'm curious of any new/old owners who also have adopted this philosophy?
Not that it means anything, but I've broken in multiple sportbike engines this way, a car or two, and I've never encountered any problems. One of the bikes interestingly enough, I did the break-in on a dyno and about 6 years later did it again at the same shop and was only down 3HP, which I thought was pretty incredible. Anyway... From what I'm reading in various threads here on the forum it looks like most folks are keeping it "by the book", and I'm just curious if the rationale is that you believe in it? Is there diagnostic data that BMW can start digging into as an excuse to void your -W-? Something other? TIA, if you're willing to share! |
06-22-2023, 04:25 PM | #13 |
Rep 706
oh no, not again, I'm not gonna bite.
Been rehashed over and over. |
Invisiblename352.50 |
06-23-2023, 12:43 PM | #14 | |
Neophyte
110
Rep 54
I just want to read (primarily) if it has something to do with concerns that BMW is "Big Brother-ing" people. At the end of the day, I know my my preference is; appreciate the response though. |
06-23-2023, 03:45 PM | #15 | |
Rep 125
Here is my 2 cents - BMW cars monitor EVERYTHING and record that monitoring. Their manual calls for a 1200 mile break in. If you are happy with the probability of nothing happening if you exceed the recommended RPM, speed, etc then have it. If you're not, then 1200 miles isn't that long of time to wait.
2023 BMW M240i - Lady Neith
Gone but not forgotten: 2021 MINI JCW GP • 2016 MINI JCW • 2012 MINI Couper S • 2010 MINI Cooper S Camden Edition |
06-23-2023, 05:24 PM | #16 | |
Neophyte
110
Rep 54
06-27-2023, 04:12 AM | #17 | |
Rep 2,070
As others have said, 1200 miles run in by the book then gradually bring up the engine load and revs to remove any potential BMW recourse or limit future issues, seems a small sacrifice to me. |
~Barn~109.50 Invisiblename352.50 |
11-20-2023, 11:33 AM | #18 |
Rep 107
I thought it was 1000 miles for non-"real" M cars and 1200 for "real" M cars. Although it's a fine point.
Re the easy vs hard break-in, I remember reading in Road and Track years ago that if you use an engine hard when new it will eventually wear out faster in the long run. But I have an airplane and those engines are broken in by running at full throttle for the first 10 hrs. With those, the teaching is the rings won't seat and you'll have to redo the cylinders if you run it lightly at first. I'm not sure what to make of these opposite recommendations. |
12-03-2023, 08:11 AM | #19 | |
Rep 1,164
(Is running the engine at full throttle for 10 hours really in the craft's owners manual?) At any rate, the engine maker is the only authority on break in for its engines. My advice is to follow the break in guidelines in the owners manual. |
03-14-2024, 03:04 PM | #20 |
Rep 1,739
An old thread but…
I have not driven over 100mph. I’ve tried to vary speed while driving for long periods on the highway. I’ve kept rpm’s below 4500. I haven’t done any hard accelerations from a stop, and have avoided downshifts while accelerating. Certainly no launches. Hell, I’ve even let a guy in a Camry force me to get out of the fast lane because I didn’t want to push it. That was the hardest of all. I’ve been good and I’ve been restrained. I now sit at 1198 miles. What does “the engine and vehicle speed can gradually be increased” mean exactly? How gradual is gradual? Can I go over 100? Can I get a little pushed back into the seat from a red light? And most importantly, do I have to move aside for Mr Camry if I don’t feel like it? |
03-14-2024, 03:15 PM | #21 | |
Rep 451
03-14-2024, 05:05 PM | #22 | ||
Rep 2,070
Increase revs by 1000rpm every 200 miles until max BTW, speed isn’t important- it’s the revs. Keeping it to below 100mph is irrelevant. |
Fronzdan304.00 |
