05-20-2023, 05:07 PM | #1 |
Rep 92
Drives: 21 x3m
e85 stock
Anyone run e85 mix (ie e20-e30) on an untuned/no piggyback tune car?
05-20-2023, 07:20 PM | #2 |
2022 M4 Comp Xdrive
1019
Rep 1,538
05-21-2023, 08:13 AM | #3 |
Rep 92
Drives: 21 x3m
Is there any type of gauges that will read/display the e content. I know for my GMJunk Aeroforce will read/display it once I install (and pin out) the GM FlexFuel sensor.
Got a little worried when I notice the sticker on my local e85 pump that said min content 51% :P hard to calc e15-20 when your pump could be dispensing e50-e85 |
05-21-2023, 08:18 AM | #4 | |
2022 M4 Comp Xdrive
1019
Rep 1,538
Cheaper option is to just get a e85 tester like this one: https://a.co/d/c7x9UiC It will let u know the ethanol content of your e85. You can then use a calculator such as https://www.morepowertuning.com/emix This will allow you to mix the right amount of ethanol to your pump gas to get to your desired ethanol level. |
05-21-2023, 08:37 AM | #5 | |
Rep 92
Drives: 21 x3m
https://www.p3cars.com/bmw/p3-v3-obd...uge-2008-2013/ |
05-21-2023, 02:12 PM | #6 |
381
Rep 372
I've known of people running up to e30 but I would stick with e20. I ran both e mix and race gas mix at the track. e did provide better results.
2022 BMW X3M - 11.604 @117.96
Gone But not forgotten 2008 BMW 135 - 10.9 @ 131 2016 BMW X6 |
07-01-2023, 06:11 AM | #7 |
DisplacementReplacement
428
Rep 1,117
E20 is fine...
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
