06-07-2023, 07:50 PM | #1 |
Rep 401
Drives: G42,570GT,Lp5704STS,F36,F34
Garage List 2023 BMW m240i [10.00]
17 Mclaren 570GT [9.50] 12 Lambo Supertrofe ... [0.00] 04 Lambo Gallardo ( ... [0.00] 08 Aston Martin Van ... [0.00] |
Injen EVOLUTION COLD AIR INTAKE SYSTEM - EVO1108
Arrived a few days ago.
Plastic is solid, hard, matte finish. Pretty good quality. Seems like a sealed system. Injen EVOLUTION COLD AIR INTAKE SYSTEM - EVO1108 Dyno Proven gains of up to 13 hp and 11 lb-ft. of torque Manufactured from high-strength XLPE Roto-Molded Polyethylene Designed to work with the stock calibration Box seamlessly adapts to the OE inlet scoop without modification Dynamic under hood appearance while maintaining an OE fit Intake scoop integration is designed to capture the largest amount of cool air for max performance Aggressive intake growl under acceleration Simple drop-in installation can normally be completed within 20 minutes Reinforced automotive grade silicone couplers Air Filter attaches to the airbox using our patented TwistLock method Fully serviceable 5.00" I.D. Injen SuperNano-Web dry air filter Made in Pomona California, USA Injen Technology Limited Lifetime Warranty |
06-08-2023, 07:58 AM | #2 |
Rep 1,954
Thanks for posting, please be post some sound clips.
If my Dinan backorder doesn't ship tomorrow as expected I may pick up one of these. |
06-08-2023, 09:17 AM | #3 | |
Rep 401
The Eventuri AI is just too much (relative price) for this car so went with Injen which is sealed. It just doesnt have the fancy carbon fiber that Eventuri has. I still have to figure out when it will be installed but will let you know. |
06-08-2023, 09:37 AM | #4 |
Joint Chiefs of Staff
24199
Rep 190,807
Congrats
06-08-2023, 09:38 AM | #5 |
Rep 56
Something I saw on the Supra FB group the other day. Just wanted to share. I canceled my order for that reason.
cosmicphotons43.50 |
06-08-2023, 03:04 PM | #6 | |
Rep 1,954
viperx100627.50 |
06-08-2023, 03:20 PM | #7 |
249
Rep 314
exactly what I thought!
I doubt, therefore I might be.
06-08-2023, 05:15 PM | #8 | ||
Rep 149
06-11-2023, 01:50 PM | #9 | |
Rep 401
But supposedly heat soaked air pulls power away or runs engine way hotter for longer periods of time which could affect engine longevity and components of the engine. For example 1st/2nd gen lambos engine run really really hot that usually any engine over 50k kms should have the top engine gaskets be all changed due to it being brittle due to longivity of extreme heat and cause sweating and leaks from the engine. Ive seen many other positive posts from Injen but would like to the see the whole story on the Supra. Keep in mind those air filters are pretty common in a lot of CAIs and all made in china. |
09-08-2023, 05:16 PM | #10 |
Rep 634
09-11-2023, 11:18 AM | #11 |
I drink and I pretend to know things.
119
Rep 226
09-11-2023, 02:07 PM | #12 |
Rep 634
Hmm, there are probably hundreds of thousands of Injen intakes installed on vehicles across the globe. If this type of disintegration was caused by common oil and fuel vapor , there would be many more instances of this happening . This is the first time I've ever heard of it happening
My guess is that before the person installed it, maybe while the filter was on the garage floor or a workbench , it came in contact with a puddle of solvent or some other corrosive fluid . Or maybe it was sprayed off with brake cleaner before install. Who knows , i don't have facebook to follow up with that Supra post |
Sonic RR118.50 |
09-12-2023, 11:49 AM | #13 | |
24199
Rep 190,807
09-13-2023, 04:30 PM | #14 |
Rep 22
Do I need to be tuned for this out of curiousity?
Vudumonkey25613.50 |
09-13-2023, 07:58 PM | #15 |
Rep 634
Typically, no.
Minor mods like intake, exhaust, downpipe etc. will do fine with the stock tune. The ECU will adjust for the minor increase of air flow / exhaust flow. But of course a tune would let you squeeze a bit more power out of these type of simple bolt on mods. |
Isamu9827.00 |
09-14-2023, 10:09 AM | #16 | |
24199
Rep 190,807
