Tirerack
  E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Tire Pressure?
Reply
      07-10-2005, 06:11 AM   #1
Teeman
Drives: 2006 Arctic 330I
Tire Pressure?
A few days after picking up my 330i, I decided to check my tire pressure. I found that they had 45lbs all the way around. The manual indicates 32 front, 36 rear. The tires are the Bridgestone Potenzas that come with the sport package, but I felt I needed to bring the pressure down to the manual's recommendations. Any one know if the performance tires require a higher pressure than the manual recommendation?
      07-10-2005, 08:30 AM   #2
E90Fleet
South Africa
1312
Drives: BMW
Look at the sticker on the driver door for tire pressures for each tire size
The dealer probably didnt adjust the pressures the tires were set at for shipping
Remember to check the manual how to reset you tire pressure monitor when you change the pressure
      07-10-2005, 09:12 AM   #3
Broken1
Addict
Broken1's Avatar
203
Drives: 2024 X5 40i M-Sport
I always check my tyre pressure when collecting my car from the dealer, you would be surprised how lazy they get.
      07-10-2005, 09:18 AM   #4
RichReg
RichReg's Avatar
Drives: 2015 435Xi GC & 2000 323Ci.
My sales manager warned me about that. Sure enough, he was right.
For some reason, and I'm guessing this is beacuse of all of the high speed roadways that are in Germany, the tires are set up with a really high PSI from the factory.
      07-10-2005, 03:46 PM   #5
visor
BMW, can I have some LSD please?
visor's Avatar
Drives: 2017 F30 340i xDrive
No, the high factory pressures is to prevent flat spots from forming on the tires during storage and transport across the Atlantic.
      07-10-2005, 06:53 PM   #6
Teeman
I figured it was a transport thing, having to do with flat spots, which is why I corrected the pressure. But then I got to thinking maybe there was something about the performance tires that required a higher pressure. Well a word to everyone before you prematurely wear out your tires, check the pressure after picking up from the dealer, and initialize the pressure monitor in the car's computer.
      07-11-2005, 10:32 AM   #7
itznin
itznin's Avatar
26
Drives: 2013 F30
This is indeed true, my 325i E90 had excess pressure as well. The car drove like a new machine after releasing some pressure.
Reply
e90post
