09-11-2023, 01:50 PM | #1 |
Rep 52
Drives: X3MC
wheel fitment gurus, any suggestions?
I have a set of bc forged wheels that came off my Audi sq5. Specs are 21x10 et 33 front/ et 30 rear. I’d love to be able to run these on the X3M but unsure what spacers I’d need to caliper clearance and have a flush fitment with 265/40 & 295/35 tire setup. I’m currently running oem 892M wheels with 12mm spacers all around and lowered on MSS springs. Any help would be much appreciated! TIA
09-11-2023, 02:45 PM | #2 |
Rep 35
I forget the name but there's a site that lets you put stock rim size and offset, then input new rim size and offset.
Tells you if it works or need spacers etc. Maybe someone else knows the actual name lol |
ThirstyX3M105.00 |
09-11-2023, 08:27 PM | #3 | |
Rep 1,102
https://www.wheel-size.com/calc/ https://www.willtheyfit.com/ |
ThirstyX3M105.00 |
09-12-2023, 09:34 AM | #4 |
Rep 999
With a 21x10, you'll need at least an effective offset of et25 in the front to clear the suspension side. Ideally I like et23 for a little more clearance.
So up front 10mm spacer and in the rear I would do an 8mm to put them flush with each other. Here is a 20x10 et23 front and et25 rear.
TacosRule!662.00 ThirstyX3M105.00 |
09-12-2023, 09:38 AM | #5 | |
Rep 1,102
Damn, what size rubber is that running? Does it rub on full lock? |
09-12-2023, 09:45 AM | #6 |
Rep 999
I'm running 275/40/20 squared. I've never rubbed
TacosRule!662.00 DBU234.00 |
09-12-2023, 11:18 AM | #8 | |
Rep 52
Drives: X3MC
09-12-2023, 01:24 PM | #9 |
Rep 999
It will still be just as flush and no risk of rubbing. I ran that same tire combo on slightly different spec of 21" wheels but effectively the same fitment and had zero problems. It will look awesome!
ThirstyX3M105.00 TacosRule!662.00 |
09-12-2023, 01:55 PM | #10 |
Rep 52
Drives: X3MC
Great to know! I really appreciate your time and info, looking forward to getting them put back to use! Thank you!
09-12-2023, 02:01 PM | #11 |
Rep 999
Not a problem! Do share photos when you do, those are gorgeous!
ThirstyX3M105.00 95wildtt857.50 |
09-12-2023, 02:11 PM | #12 |
Rep 52
Drives: X3MC
09-13-2023, 12:36 AM | #13 |
Tuned ///M Cars Only
143
Rep 337
Drives: '21 F87 M2C |'20 F97 X3MC
I run 285/35/21 on the fronts and they rub just a bit
2020 X3M Competition Stage 2 | Black Metallic Sapphire
2021 M2 Competition | Hockenheim Silver Special Content Tesla Model 3 Stealth | Wrapped AD Satin Metallic Pearl White Instagram: F97_KT |
09-15-2023, 06:43 PM | #15 |
Rep 999
No I haven't. It would fit fine on the wheel but thats 2.5% larger than stock. No go for me personally. 275/40/20 has a bigger selection of tires too.
09-15-2023, 07:26 PM | #16 | |
Rep 1,102
So maybe you can help me figure out how to fit 789Ms. These are the specs for the front wheel ** FRONT ** Product: Wheel/Rim (Single) Fitment: Front Material: Forged Aluminum Style: 10 Y Spoke Finish: Gold Bronze Size: 20x9.5 Lugs: 5 Bolt Pattern: 112mm Offset: 28mm Option Code: Style 789M OE Part Number: 36119501872 Using the calculator here and comparing them to my OE 764M fronts (20x9), with a 275-40-20 tire https://www.wheel-size.com/calc/?whe...cl=30mm&sr=0mm The front 789M (20x9.5) in my 2022 X3M is: Suspension Tire 10mm closer to suspension components. Rim 6mm closer to suspension components. Acceptable for most cars Fenders Tire stick out 10mm farther. Rim will stick out 6mm farther. Acceptable for most cars Wheel Wells Wheel fills out wheel well by extra 9 mm. Acceptable for most cars Brakes The same Scrub Radius Negative scrub radius ~-3mm. Almost no difference. Calculated value is approximate. Personally, I dont like the numbers. Is this 789M out of the question? |
09-15-2023, 07:30 PM | #17 |
Rep 1,102
Conversely, using the front 20x9.5 789M rims (28mm offset) in the rears with the same 275-40-20 and 11MM spacers:
11 MM (TOTAL 39 MM OFFSET, SAME AS OE 764M) Suspension Tire is 5 mm closer to suspension components. Acceptable for most cars Fenders The tire will stick out 5 mm farther. Acceptable for most cars Wheel Wells 100% clear (leaves even more room than OE) Brakes SAME AS OE Scrub Radius Positive scrub radius (about 3 mm). Almost no difference. Please be aware that calculated value is approximate. This feels perfect. I want the same numbers in the front... |
09-15-2023, 08:37 PM | #18 | |
Rep 999
With 9.5 wide you dont have to worry about suspension clearance as much. On the fender side they'll be flush with a tiny bit of poke. Those paired with 275/40/20 are perfect. Ironically enough, my dad runs those exact specs on his X3M for winter. And I run the same on the front if my car. Neuspeed RSe102 20x9.5 et25 with 8mm spacers (effectively et17 275/40/20 Vredstein winters
09-16-2023, 02:02 PM | #19 | |
Rep 1,102
Thanks again, that's a gorgeous stance. Help me understand tho, if I add 11mm spacers to 28mm offset, wouldnt that make them 39mm offset? The numbers on that calculator freak me out. Or is the calculator wrong? |
09-18-2023, 09:00 AM | #21 | |
Rep 999
Think of the wheel spacer like it's adding material onto that back back so you would be lowering the offset even more. So a 20x9.5 et18 wheel will fit the same as a 20x9.5 et28 wheel with a 10mm spacer. Regarding your next post; 20x9.5 et28 will likely work however I personally think they look a little too sunken into the wheel well for me. Up to you!
TacosRule!662.00 |
09-18-2023, 01:40 PM | #22 | |
Rep 1,102
Thank you for your patience. I am an ignoramous when it comes to wheels. I've never done aftermarkets at all, so its a learning curve for me. 11mm it is! |
