11-06-2023, 07:12 AM | #1 |
451
Rep 357
Chassis function restricted
Hi All,
Just thought I'd share in case someone else has experienced a similar error message.."chassis function restricted" error message. I had been getting this message occasionally for the past year or so but it didn't bother me much as it was intermittent, showing up sometimes whenever I started my car up, cold or warm. The fix for this was turning the car off and back on again. My 2021 is still under warranty, so today I took it in for a check up as the message appeared last Friday and for some reason, the message wouldn't go away with a restart of the car. I tried this 5 times with no luck, so I decided to turn off the car for ~ 10mins, and the error message disappeared Diagnosis at the dealer took a couple of hours, and the front right strut is the culprit amd requires replacing as it is faulty. |
