BMW 5-Series (G30) Forum DIY Discussions / Guides / Instructions 2018 530I Aux. Battery Replacement Question
      01-03-2024, 01:36 PM   #1
migrant
Drives: 2018 BMW 530I
2018 BMW 530I  [0.00]
2018 530I, looking to change the auxiliary battery in the engine compartment. Label on the battery (original Varta) reads 50AH 570CCA.
Online matches (Autozone, Amazon) are rated at 14AH 200CCA
Can someone please advise what non-BMW battery to buy?
I used AC Delco Gold for the main battery, would prefer the same for aux.
https://www.amazon.com/ACDelco-Profe...=2018+BMW+530i
      01-16-2024, 06:28 PM   #2
flipicaneze
Drives: BMW 540i xDrive
https://www.interstatebatteries.com/...i-xdrive-l420l
If I am not mistaken, I think the battery under the hood is the H6 from Interstate.
For the actual BMW part number look up 61-21-6-805-461 for the 70AH. Unfortunately my local dealer (bmwpartsnow.com) doesn't sell the batteries, must be they want to charge for the install themselves.
430Scud253.00
      01-18-2024, 07:07 AM   #3
Mosaud1998
Mosaud1998's Avatar
Drives: 2019 BMW 540
2019 BMW 540  [0.00]
There's an auxiliary battery? I thought there was only one and that's under the trunk.
Current: 2019 BMW 540 (AWD)
Sold: 2009 BMW 328 (AWD)
      01-27-2024, 01:36 PM   #4
430Scud
430Scud's Avatar
253
Drives: M550iX,430 Scud,E39 540Msport
Generally there are two. The trunk battery is the main or starting battery. The aux battery is in the engine compartment, and (I believe) is used whenever the engine is off, when using the "start stop" function. The aux battery keeps all the accessories, headlights and HVAC running. This way it does not run down the main battery and the car will start easily when you step on the gas pedal.
      01-27-2024, 04:35 PM   #5
maDjzo
maDjzo's Avatar
Poland
862
Drives: G30
2018 BMW M550i  [0.00]
ACDelco 88866037
I believe that’s a direct replacement.
RealOEM shows OEM part: 61219364597
https://www.summitracing.com/parts/ado-ln1agm
5post
