03-02-2024, 11:41 AM | #1 |
Rep 44
Vargas GC Turbo Inlet Question
Hey all! Recently installed Vargas GC on my 23 M240i. Looks like the turbo inlet that is supplied does not have a connection for the PCV sensor that is closest to the turbo. Wanted to see if this is something others dealt with as it’s now throwing a CEL - which is obviously annoying if your OCD like me. Waiting to hear back from my tuner on the matter as well as Vargas but thought if anyone had any words of wisdom I’m all ears!
03-08-2024, 03:55 PM | #3 |
Rep 44
Hey! So it lacks a spot for the sensor. It had the connection for the PCV system. It is the correct pipe. You just need to code it out using BM3s section at the bottom of your map settings. If you can’t do it your tuner should be able to! I was able to successfully do it on my own in BM3 but I know some people still had the CEL even having done that and required their tuner to remove it. Vargas confirms this with me and a few guys on the B58 Facebook group also confirmed. So it’s normal!
VegasG42388.50 |
03-19-2024, 12:29 PM | #5 |
Rep 44
