BMW 3-Series (E90 E92) Forum
Alloy Advice!
04-06-2009, 05:37 PM | #1 |
Rep 2,402
Alloy Advice!
i found a set of 18" M6 Rep alloys for a great price the sizes are :-
18x8 ET40 front and deeper 18x9inc Et32 rear Will they fit my car without spacers? The reason i'm going for 18" is ive just had a brand new set of tyres that cost £700 and i aint buying any more! They are saying the tyres to fit these alloys are 225/40/18 front and 255/35/18 rears Which are the same size that fit on my current 18" MV3 BMW original alloys, are these sizes correct for the alloys above and i'm correct in saying i can just swap them over? Would it be ok to put my runflats on these? if i do there will be a set of 18" MV3 OEM BMW alloys for sale! This isn't my car but its the same what do you think?
04-07-2009, 01:08 AM | #2 |
Rep 6,912
Nice looking wheels - I was considering these vs the MV3 for my winter wheel set, but having seen the picture, I think I'm sold.
Not sure where they are from, but I'm probably going to get mine from MStyle. Can't help with the other stuff I'm afraid!
E92 M3, Jerez Black, Fox Red Novillo, 19'' M Double Spoke, folding mirrors, lumbar support, front seat heating, PDC, USB, DAB, EDC, Bluetooth, Logic 7, High Gloss Shadowline, big smile
04-07-2009, 05:17 AM | #3 | |
Rep 2,402
If i do my MV3's will be for sale at a good price! |
04-07-2009, 06:35 AM | #4 |
Moderator
324
Rep 5,493
You called?!
Right, with regards to your offsets: The fronts will fit on no problem - they will sit 3mm closer to the hub, but that shouldn't be a problem as there should still be enough clearance. If you wanted to use a 5mm spacer, that wouldn't be a problem either. The rears are a bit different - the offset on your proposed wheels is ET32 - standard is ET39 for a 9J wheel. That means that your proposed wheel will sit 7mm further out into the wheel arches. I don't think there'll be a problem with rubbing, but I'm not completely sure as yours is a saloon and not a coupe. The tyre sizes you've mentioned are the correct sizes. Bridgestone runflats (the sidewall-reinforced versions) can be installed on a conventional wheel. I don't know whether that is true of other runflat brands however.
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
04-07-2009, 08:29 AM | #5 |
Rep 2,402
i knew you would!
thanks for that, i will ask them if they have had any problems with the rears rubbing. the tyres i would put on are the bridgestone runflats RE05A or something like that! am i right in thinking the front track will reduce by 6mm in total and the rear would extend out 14mm in total? Will this affect the handling of the car and would the alignment need re doing? Thanks tone, |
04-07-2009, 08:56 AM | #7 |
Rep 2,402
i know it makes sense!
04-07-2009, 10:18 AM | #8 |
Defected to the dark side.....
210
Rep 5,795
Drives: BMW M5 LCi
They look good on that black saloon - go for it
We will have to have our very own 'M6 reps Staffs' meet lol Have to be quick though, as mine will be coming off in a few weeks as I start to get it back to standard |
04-07-2009, 10:35 AM | #9 |
Rep 2,402
i know that's the problem
Think i will ponder for a while longer! We do need to have a Stafford meet especially when you get the M3!!!!!!!!!!! I'm almost as excited as you |
04-07-2009, 11:29 AM | #10 |
210
Rep 5,795
Drives: BMW M5 LCi
04-07-2009, 11:31 AM | #11 |
Rep 2,402
Suppose your right! Dont know how you sleep at night
04-07-2009, 11:34 AM | #12 |
210
Rep 5,795
Drives: BMW M5 LCi
04-07-2009, 01:43 PM | #13 | |
Rep 29,202
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
04-07-2009, 01:47 PM | #14 |
Rep 2,402
