BMW 3-Series (E90 E92) Forum
E90 offset help
06-23-2009, 02:32 PM | #1 |
Rep 158
E90 offset help
Hi All,
Please i need some help with this my E90 was running 8.5"-19" front et35 with 235/35 tyres and 9.5"-19" et32 275/35 rear with sports suspension but lowered 10mm rear and 15mm front on eibach pro-kit. Had no problems with this set up but now looking to change to new wheels but new off sets are et40 front and et27 rear, should be ok at the rear as arches have been rolled but would like to run 245/35 tyre on the front, would this work or would it rub on the strut or inside the arche any where. Many Thanks for any help given. |
06-24-2009, 05:04 PM | #2 |
Rep 1,736
Drives: '09 E92 335i
You'll be close but can probably get away with a 245 tire on an 8.5", +40 wheel. If not, you can always do minor fender work up front. Since you're lowered, you may rub the top of the tire against the plastic fender well on abrupt bumps at speed. That, however, shouldn't damage your fender or tire.
| 6MT | ZSP | ZPP | |
06-24-2009, 06:06 PM | #3 |
BimmerPost Supporting Vendor
2050
Rep 25,989
Fronts may rub during compression since you are lowered. I generally stick with a 235 to stay on the safe side if you are looking not to roll the fenders.
The 9.5 +27 rears may have some rubbing issues depending how aggressively you rolled the fenders. -Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
06-24-2009, 07:13 PM | #4 | |
Rep 99
06-24-2009, 10:02 PM | #5 |
Rep 997
245 will work in the front without rolling fender, but ET40 might rub the struct, just buy a pair of 5mm spacer.
FS: OEM M Sport Rear Sway Bar
http://www.e90post.com/forums/showthread.php?t=246838 |
06-25-2009, 05:36 PM | #7 | |
2050
Rep 25,989
-Charles@VMRWheels
