E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Replacing Shift Knob
Reply
      07-29-2005, 11:56 AM   #1
brad4221x
Drives: E-90
Can anyone give me help in swaping out a automatic gear shift selector on an E-90?
      08-13-2005, 11:43 PM   #2
a burrito
Drives: Urus, 958.2 TTS, 997 S
this may not be the same but for the e46 all you had to do was put it in nuetral with the handbrake up and pull upwards as hard as you could.
Peanut Butter Chunky
      08-19-2005, 07:36 PM   #3
AW330i
AW330i's Avatar
Drives: Alpine White 330i
I am fairly certain it is different on the E-90, I seem to remember hearing that the E-90's is a screw on wich if I rememer correctly you have to pull up the shifter boot and then twist the shifter off the shaft but not sure about that...
      08-30-2005, 05:59 PM   #4
Dalscboy
Drives: 2006 BMW 325i
I just swapped out the automatic gear shift and it took about two minutes. the lever pops right off if you pull it up and the leather boot will also pop right out. just pull the leather boot back over the lever holder and insert the new lever into the hole until it clicks in. the leather boot will pop right back into the console. its pretty easy.
      09-02-2005, 12:33 PM   #5
longtran
longtran's Avatar
1433
Drives: E90 M3
2006 325i  [0.00]
repeat the steps and take picture as you go. i would like to see this. thanks.
Reply
e90post
