BMW 3-Series (E90 E92) Forum
Brake pads front and back
12-13-2009, 10:03 AM | #1 |
Rep 2,204
Hi all,
I need pads front and back for an E92 335d M, where is teh chepeast place to get genuine parts. Thanks.
Engine Mods: VF HEX Stage 2, ER Charge Pipes, VRSF Catless Downpipes, BMS Intakes and PCW Exhaust Mod
Running Gear Mods: HRE Flow Form F01, Yellow Stuff pads. Cosmetic: Performance Grill, Lip Spoiler, Splitters, Side Skirt Extensions, Diffuser and BMS Tips |
12-13-2009, 10:06 AM | #2 |
Rep 797
Drives: BMW 320d Le Mans Blue
you will need sensors as well.
12-13-2009, 10:17 AM | #3 |
Rep 2,834
Not sure if they do OEM or not but try Eurocarparts:
http://www.eurocarparts.com/ecp/p/Car-Parts I tend to get all my consumables from these guys. Decently priced and the service is great. They have outlets around the country and my local one is very close by so I tend to stick with them. |
12-13-2009, 10:33 AM | #4 |
Come as you are
137
Rep 1,404
12-13-2009, 10:42 AM | #5 |
Rep 793
http://www.bmminiparts.com/ do genuine parts cheaply - never used them though, so can't comment on the service...
12-13-2009, 11:12 AM | #6 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
ECP etc won't supply OEM BMW parts - the link above is probably your best bet.
12-13-2009, 12:06 PM | #7 |
Dieseasal
204
Rep 6,881
Has anyone bought from the guys above successfully? They are pretty cheap. I might use them as I need to buy some new pads myself actually.
Previously: 2003 Peugeot 206 1.6 8v | 2006 E90 320d M-Sport, 19" BBS CH, Full Ice-cold JL audio install, August 2010 Total BMW 6 page feature car. | 2003 Nissan 350Z GT Coupe 286BHP
Now:2010 E92 LCI 335d M-Sport |
12-13-2009, 02:31 PM | #8 |
Rep 564
Drives: e90 320D ED
i bought some bosch equiv from GSF a few weeks back, about £50ish for the fronts with sensor.
Its all about the mpg!
12-13-2009, 02:47 PM | #9 |
112
Rep 5,541
All brake pads will meet the E90 Spec which means the pad has to meet certain OE criteria.
Lower RH corner, have a read if you're interested. http://www.mikewoodtyres.co.uk/delphibrakepad.pdf
12-14-2009, 03:40 AM | #10 |
Rep 2,204
I am mate - but it still needs brakes :-)
Are Pagid pads ok ?
Running Gear Mods: HRE Flow Form F01, Yellow Stuff pads. Cosmetic: Performance Grill, Lip Spoiler, Splitters, Side Skirt Extensions, Diffuser and BMS Tips Last edited by lolololol; 12-14-2009 at 04:08 AM.. |
12-14-2009, 05:12 AM | #11 |
Dieseasal
204
Rep 6,881
They are infact very good!
I take it your not giving the car back to BMW though? As they won't run it through AUC with anything other than OEM..
12-14-2009, 11:27 AM | #12 |
Rep 2,204
Thanks for that - no the car will never be going back to BM AUC especially for what they offer !
12-14-2009, 01:21 PM | #13 |
112
Rep 5,541
How would they ever know???
12-14-2009, 02:07 PM | #14 | |
Rep 8,972
The you see all sorts on AUC, aftermarket wheels all sorts. You think they'd check for brake pads??? They don't even know if you've got runflats on - couldn't give a toss. |
12-14-2009, 02:11 PM | #15 |
Dieseasal
204
Rep 6,881
Well thats what they stay. As for aftermarket wheels, I know some who definitely wouldn't touch them! Even if some would.
Just quoting letter of the law. Whether that many of the dealers actually follow through with their claims is another matter. But valid point, they are brake pads. Like they are going to spot that. So fair play.
12-14-2009, 04:35 PM | #16 |
Rep 9
Just had the car in for an oil service at the stealers today, whilst there asked for quote to change front discs n pads etc - price £462.06 inc. Service manager did say might be able to sharpen his pencil to tune of @ -10%.
Question. Has anyone got any experience of having front discs skimmed in a lathe, mine have suffered from bad corrosion due to car being parked up outside for extended periods, result bad vibration when braking hard from high speed. |
12-15-2009, 12:31 AM | #17 |
112
Rep 5,541
Yep, I've got a special on-car lathe for this very problem. Works a treat.
12-19-2009, 03:18 AM | #18 |
112
Rep 5,541
How did you get on in the end Omar?
12-19-2009, 04:53 AM | #19 | |
Dieseasal
204
Rep 6,881
