BMW 3-Series (E90 E92) Forum
whats up with my rear camber
03-06-2010, 04:43 PM | #1 |
138
Rep 2,731
rear camber
firestone got it right on the edge of being in spec. but the range that shows as in spec is pretty big and im wondering why they couldnt get it closer to the center of that range. are they lazy? do they lack the right tools? is it something that just cant be adjusted past a certain point without aftermarket parts? |
03-07-2010, 06:52 PM | #3 |
Rep 3,955
depends on if it is a preloaded spec or unloaded spec. The reading will be different for each or wrong depending on what they did.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
03-07-2010, 07:15 PM | #4 |
138
Rep 2,731
forgive my ignorance but i dont know what that means. something to do with having a weight in the driver seat? if its that sensitive would a full or empty tank of gas throw it off also? curious
03-07-2010, 07:25 PM | #5 |
Rep 3,955
correct, weights in both front seats and the trunk. BMW's new system no longer requires preloading, but now measure ride height of all 4 corners so the system calculates by height on suspension option. It's very slick. But what is more important is if a shop uses preloaded specs while not loading the car and vicea versa. As far as edge of spec, it depends on what you want and which side of spec, least or most.
03-07-2010, 07:32 PM | #6 |
138
Rep 2,731
i see why it pays to do the alignment at bmw. ive been doing mine at firestone, the car has lifetime alignments there. not sure if they loaded it or not but i know the machine had two arms with rapid flashing red led lights and a couple of kinda triangular waffle looking things.
03-08-2010, 11:21 AM | #8 |
Rep 723
03-08-2010, 11:42 AM | #9 |
138
Rep 2,731
03-08-2010, 11:52 AM | #10 |
55
Rep 1,495
the more negative camber you have(the more the tops of the wheels are tipped inward), the better the car will handle in corners...to a point. The middle of spec would put it in a very nice daily driver, tire consuming configuration. Toe is another thing to look into as well. It's how much the fronts of the wheels turn in towards or away from each other, like being pigeon toed or whatever the opposite is. I would always have them set toe at 0 and camber dead nuts in the middle if it were me. Gets you the best tire wear and the car still handles great.
03-08-2010, 03:24 PM | #11 | |
138
Rep 2,731
03-09-2010, 10:18 AM | #12 |
Rep 723
camber doesn't affect your wipers. that's caster
03-09-2010, 11:25 AM | #13 |
Rep 3,955
Yes it is bad to go to less camber from a performance standpoint. Just for example, this is what I run . The second pic is with BMW's new alignment setup that does not require preloading but ride height measurment at each corner. The first set up is with the car preloaded. As you can see, the alignment method makes a difference on readings especially when the new set up is in degrees and minutes that you have to convert and even then they don't fully match. The BMW system is now way complex, but it custom tailors each alignment to the ride height of the car and I think that's slick especially since I am lowered. The tech and I tailor the alignment for my preferences.
03-10-2010, 08:23 AM | #15 |
Rep 3,955
No. You can see the stock ranges above.
