BMW 3-Series (E90 E92) Forum
Wheel noice question / help . . .
07-30-2010, 08:22 AM | #3 |
Rep 6,317
have your wheels balanced and do an alighnment. You should do that anyway after getting wheels from some forum member. during balancing it will be clear if there is a problem with the rims..
as for putting a spacer, i'm not sure if you're kidding.
F30.F11.E86.E90.E90.E36 |
07-30-2010, 08:37 AM | #4 |
Just another guy. . .
43
Rep 214
Hey thanks, I'll get an allignment/balancing done. And I only mentioned spacers because someone suggested for me to put them on because he said that might get rid of the noice/sound. Thanks for the advise. . .
07-30-2010, 08:44 AM | #5 |
The Ultimate Driver
16
Rep 129
Do you hear the noise when you are turning or going straight?
Check the tires for any unusual wear. Then you might be able to pin point where it is rubbing
RTS Tune - RTS Forged 8 Wheels - Akrapovic Exhaust - Stett CAI & Charger Pipe - Mtec A.E. Upgrade.
Coming Soon - Coilovers - MTech Kit - Upgraded Turbos. Rich Tuning Systems |
07-30-2010, 09:26 AM | #6 |
43
Rep 214
I hear it when I do both. I checked the tires, around the fenders, shocks and didn't see any wear at all or any sign of rubbing that's why I wasn't sure what was going on.
07-30-2010, 10:05 AM | #7 |
Rep 2,384
check air pressure could cause unusual wear, also get the wheels balanced and aligned properly because this could stop some vibrations etc. i had this same problem on an 09 mini cooper and it went away with some decent balancing. Also one of the rims could have a slight bend causing this
07-30-2010, 10:08 AM | #8 | |
43
Rep 214
