BMW 3-Series (E90 E92) Forum
Airsoft: One of a Kind Custom Tokyo Marui M4A1
01-07-2007, 10:30 PM | #1 |
Rep 8,338
Please refer to this post instead: http://www.e90post.com/forums/showth...712#post676712 Mods please close this thread $650 + shipping to your doorstep, or best offer For $700 I will sell the rifle with it's matching silencer, two batteries, 1 standard cap magazine and carry bag. That's on top of everything you see there. Now that my 335i has arrived it's time to do some modding, but I need to free up some money first. My greatest hobby before cars was airsoft, the peak of which gave birth to this: The gun itself is a Tokyo Marui M4A1 I originally bought as their DevGru custom M4 ($900). It then began its transformation, losing and gaining accessories, these are its current stats: Tokyo Marui M4A1 tuned to 400fps (385 in actuality) Guarder Metal Body Guarder 2 piece cqb barel Systema metal hop-up chamber Star ruber ergonomic grip Prime battery retractable stock G&P Aimpoint G&P Rear Flip Up Sight Phantom Flashhider superbright 13 LED flashlight high connectivity connectors (wired to the stock) Norrell MolyResin (metalbody, outterbarel, front sight, ras, stock tube, flashhider, flashlight and mount, etc.) I will also throw in a G&G silencer that is also refinished in Norrells and matchs the gun perfectly as well as a Classic Army bipod (both pictured here, before the silencer or gun was refinished however http://ironicdesigns.no-ip.com/Pictu...s/IMG_1028.jpg. Now besides the ordinary, here's the real custom part about this gun. The WHOLE rifle has been refinished with Norrell's (http://www.molyresin.com/). MolyResin is the same finish applied to countless highend arms by their manufacturers. By refinished, I mean the parts have been stripped of previous paint and been recoated in a milspec finish. The whole process took me three days to finish and atleast 10 hrs between stripping the paint and refinishing and curing. Some facts about MolyResin below. Specifications: Appearance: The bonded coating will appear uniform in color, smooth and free from cracks, runs, sags, scratches, pin holes, blisters, bubbles, and foreign matter. Thickness: The optimal thickness of the coating will be between .0003" and .0009" unless a thicker coating is desired. The thin coating characteristics of less than one thousands of an inch allows easy re-assembly of precision fitted parts Lubricity: Moly Resin™ contains molybdenum disulfide, which provides excellent anti-friction characteristics. Wear life is comparable to blued, parkerized and other common firearm finishes. Moly Resin™ is a phenolic Resin that when thermally cured, produces the most durable thermally cured painted surface of any products on the market. Wear life when tested on Tabor Abrasurf with #CS10 wheel installed @ 500 grams weight minimum 235 RPM's. Thermal Stability: The cured coating will withstand exposure at 500 f for 1000 hours minimum and 1000 hour minimum soak at -125 f. Minimum initial oxidation temperature is 880 f. Thermal breakaway is 1000 f minimum. Fluid Resistance: Moly Resin™ will meet 24 hour emersion requirements in the following fluids: aviation gasoline, hydraulic fluid, jet fuel, lubricating oils, paint removers, trichlorethylene, nitric, sulphuric and hydrochloric acids, hydrogen peroxide, gun powder solvents, strong bases such as ammonium and sodium hydroxide, and numerous other strong chemicals. Corrosion Resistance: Moly Resin™, when applied to bare sandblasted cold rolled steel will pass the test procedures for salt water spray at 1000 hours, salt water immersion at a minimum of 1000 hours, accelerated salt spray test equivalent to 30 years marine atmosphere exposure, and 60 days sea water immersion. Hardness: Hardness meets and/or exceeds the hardness of any Epoxy,Teflon or most other thermally cured firearm coating or paints on the market. Here are some photos (note: the optics pictured have since been removed, but I will throw in an aimpoint w/ cantilever mount and a NEW G&P Aimpoint). Notice the finish - this is THE MOST REALISTIC airsoft replica rifle on the market. The blemishes in the finish you're seeing, where the paint looks blotchy, is from silicone oil; the residue rubs off as well as most any other scratch thanks to Norrell's. For reference (look out how uniform and high quality the finish looks on the flat slide of the glock):
01-07-2007, 10:47 PM | #2 |
Rep 2,355
sick, but i used to airsoft, and collect......not going for this anymore.....once you buy one, then another, its addicting, and its soo cool how everyone really thinks they are real until you tell them its not
GL and BUMP, this is a sick product!
2006 E46 M3 ZCP 6SPD-Interlagos Blue - 6SPD - SSK - AA Headers -AA Tune - Navigation w/ Splashscreen Mod - 3M Crystalline Series 60 - Carbon Splitters - Swissvax Treated - Bridgestone
2012 Yamaha FZ8 - Matte Black/Grey - Michelin Pilot Pure 2CT - Vortex Rear Sets - Yoshimura R-77D & Fender Delete - Spectro Race Oil - GP Reverse Shifting |
01-07-2007, 11:16 PM | #3 |
boku no namae ha...
336
Rep 11,025
Drives: 2006 BS 330i
Location: S. Bay Area, CA + Newark, NJ + ChiCity + True Blue
tokyo marui... haha thats some good stuff... i was gonna get a m4 but not a full metal one... those cost too much.
looking for a PreLCI Black Sapphire e90 front bumper without license plate holes
"Akimbo shotguns. Broken wrists anyone? And don't give me that 'it's just a game' bull****. Where the **** are my akimbo interventions then?! One scope on each eye mother****er!!" |
01-07-2007, 11:43 PM | #4 | |
Rep 8,338
01-07-2007, 11:44 PM | #5 | |
Rep 8,338
if u ever decide to pick up the hobby again u should look into doing something like MolyResins, it really takes it to the next level - beyond just buying "custom" parts.
01-08-2007, 05:53 PM | #7 | |
Rep 8,338
01-08-2007, 06:03 PM | #8 |
Rep 16,628
one guy spend all his money modding so he cant buy this. another want to sell this to sellhis car... sick gun, good luck selling.
01-08-2007, 06:28 PM | #9 | |
Rep 8,338
01-08-2007, 07:03 PM | #10 |
Rep 2,355
ohhh, well im looking for a blowbackk model of the USP SOCOM...known as a Tokyo Marui Mk.23 SOCOM .........Its from Metal Gear Solid...if youve ever played the game you would know why i need this! lol
01-08-2007, 07:44 PM | #11 | |
Rep 8,338
01-08-2007, 07:46 PM | #12 |
Rep 8,338
Driv3r, also about the m4 i have.
those optics you see in the photo are realsteel mounts and flip up sights. The aimpoint itself isn't real (i couldn't justify spending that much on precision optics that could get shot up), but the mount for it is. This means that the rails on my m4 have the same specs as its real steel counterpart - another plus if you plan to use something liek this for training.
01-09-2007, 12:47 AM | #13 |
Rep 2,221
i have a gat foo!!
01-09-2007, 03:36 AM | #14 |
Rep 3,431
i miss my g18, that thing fires so fast with the gas, pops 23 shots in like 3 seconds in full auto, awesome feeling!!
Current: 09' E90 335d - Titanium Silver/Black Leatherette/Sports Package/6AT Paddle Shift/USB Integration/19" Staggered Breyton GT Gloss Black
Retired: 07' E92 328i (Jet Black) |
01-09-2007, 08:53 AM | #15 | |
Rep 8,338
01-09-2007, 01:59 PM | #16 |
Rep 2,355
mMMmmM
01-09-2007, 11:51 PM | #17 |
Rep 8,338
bump =)
01-11-2007, 09:09 PM | #18 |
Rep 8,338
Price drop, I'm serious about selling this $800 buyer pays shipping.
01-13-2007, 05:21 PM | #19 |
Rep 8,338
bump, this is a great deal guys
01-13-2007, 11:40 PM | #20 |
Rep 2,355
do you think it could be possible to have this gun be changed to carry tranquilizer darts? if you did that for me or could show me where to buy a tactical looking tranquilizer gun thats decently high powered....
01-13-2007, 11:40 PM | #21 |
Rep 2,355
or could this take rubber bullets?
01-13-2007, 11:43 PM | #22 | |
Rep 7,952
