BMW 3-Series (E90 E92) Forum
BBS CH 19" in arrive..
01-09-2007, 08:07 AM | #1 |
Rep 129
Yes..finally!!:rocks:
one only question.. 8,5 x 19 et35 front 10 x 19 et20 rear any problem with this setup? thanks!
Bye from Italy... |
01-09-2007, 09:59 AM | #2 |
Rep 29,202
The rear are very aggresive and you have to roll your fenders and use a rear tire that is stretched on the rear wheels. For pics, look at diesel007's car.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
01-09-2007, 10:47 AM | #3 | |
Rep 129
Bye from Italy... |
01-09-2007, 10:49 AM | #4 | |
Rep 16,628
01-09-2007, 10:52 AM | #5 | |
Rep 129
in Italy, I can't running with 275... I can only 225/40 19 on the front and 255/35 19 on the rear..
Bye from Italy... |
01-09-2007, 11:30 AM | #7 | |
Rep 129
exist another et of bbs with 10"?
Bye from Italy... |
01-09-2007, 11:31 AM | #8 | |
Rep 29,202
01-09-2007, 12:20 PM | #10 | |
Not Stock
160
Rep 2,774
Unfortunately not, these wheels were built for the e46 M3 and as we know those things have lots a room in the rear fender wells. BBS makes the CH in 19x9.5 et 40 though, but they don't have as much concave as the 10" wheels. Also you would need 10-15mm spacers to make the 40mm offsets flush with the fenders. |
01-09-2007, 01:24 PM | #11 |
Rep 2,059
When do we get to see pics? 19X10 on the rears would be awesome. 19X8.5 in the front is ideal for easier steering at low speeds. Perfeto, Buona Fortuna Senore~
330i 6MT l 255 HP @ 5900 rpm 214 lb-ft Torque @ 3500 rpm l Alpine White l Beige l Aluminum l ZSP l 494 l PDC
"Freude am Fahren" = "Joy to Drive" |
01-10-2007, 12:49 AM | #12 | |
Rep 129
buy CH or not? I don't want roll fenders...
Bye from Italy... |
01-10-2007, 01:21 AM | #13 | |
Rep 548
Even with standard sport suspension, the 19X10 et20 wheel will require fender rolling, PLUS it will rub on the plastic part of the rear bumper in the wheel well (this part cannot be rolled.) The et20 wheels stick out FAR, and you'll probably want a bodykit with sideskirts similar to ACS to "fill in" the exposed tire with the car's body. |
01-10-2007, 10:36 AM | #17 | |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
01-11-2007, 05:14 PM | #19 | |
Rep 643
They were AZA from wheelmax. They're not available at wheelmax anymore. The specs were: 19 x 8.5 Hypersilver were 35mm et 19 x 9.5 Hypersilver were 40mm et 19 x 8.5 Hyperblack were 35mm et 19 x 9.5 Hyperblack were 45mm et |
01-30-2007, 12:37 AM | #21 |
Rep 815
There is a DIY floating around (involving a baseball bat and heat-gun). I had mine rolled by a shop with the hub-mounted machine specific for this task for $20/wheel. You can rent the same machine from Tirerack, but for $40, I had it done by pros (Speed Concept, Portland). You can buy the rolling machine for ~$200 and sell it, as an aternative. I'm wary of any body-alteration DIY involving a baseball bat.
01-30-2007, 01:12 AM | #22 |
Rep 7,719
There is many ways to do it. A ghetto way would to get a baseball bat and lever it against the tire and push the bat down. I prefer shaving it off. If you were to roll it, make sure you to go to a pro or know what they're doing. Many a time, amateur jobs are noticeable IMO.
