BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > What should the next 1 series fix or address
      09-24-2010, 10:25 PM   #1
RPM90
Drives: 340i M-sport AT
Now that many of us have had a longer term relationship with our 1's, what would you like to see BMW do with the next 1 series?
What design characteristics would you change, and how, if you could tell BMW what to do, so that you would get another 1.
This is for the day to day 1 series, not an M variant, which has it's own threads of desire.
In realistic terms, what needs to happen?
Here is what I would like to see in the next 1 series:
My list is extensive, but realistic.
Exterior:
-Body changes. Keep the nice tight body proportions and even the general shape, but REMOVE the pot belly pig line and look of the mid-section. The rear looks great, so be minimal there.
-A refined front end, more evolution than revolution, perhaps some deeper and wider splitters built into the front facia.
-I like fog lights.
-Dual exhaust, at least for the hi-po engine variant, 135i.
FIX the damn side windows with real and FUNCTIONAL rain gutters/channels. I am tired of getting soaked when I use the windshield spray and wipers when the windows are open!
Perhaps stop with the frameless doors that have the "ooo, ahhhh" effect, but allow all kinds of dirt and debris into the door only to end up streaking dirt and grime on my windows only a few minutes after I've spent a couple of hours cleaning the car.
Interior:
-A real and adjustable arm rest that can adjust up and down, and fore and aft.
-A standard central color LCD display to show controls for HVAC, Radio, Cell phone, car computer MPG, MPH, etc..., that does NOT require a NAV option. Bring some "luxury" tech to the interior.
-Real brushed aluminum trim option.
-Slightly wider adjustable side bolsters, and a bit more cushion to the thigh bolsters.
-MUCH better head rest that can at least change angle, but would be better if it were like the 3 series vert headrest.
-Cooler Tach and speedometer lighting, something along the line of the 3 series gauges.
-With a central LCD display, more room to add coolant temp, oil temp, boost gauge, with a toggle to real tire pressure readout in numbers.
-Better HVAC air flow.
-A MUCH better standard audio option with subs, and enough power to jam at volume while driving 90mph with both windows open. I'm sure the vert folks would appreciate that. Oh, and add an EQ you cheapskates.
Mechanical:
-Suspension, suspension, suspension. Do it right. You know how to, ask the engineers working on the 3 series.
-Shorter clutch travel.
-Shorter clutch lever throws.
-At least a bump to 320hp/320lb ft, with a power band allowing better, flatter torque curve into higher rpm range.
-LSD, at least as a realistic cost option.
-Taller 5th and 6th gear for the MT, or at least 6th for less revs cruising at high speed, and better highway MPG.
-And NO HPFP failures.
-High performance all season tire option with the sport packages for those who still have to drive in 4 seasons conditions.
-Better next gen RFT's, or go back to regular tires and a spare and jack.
I'd kinda like to see more "pearl" colors too, like a pearl white, blue.
That's about it.
To distill the most important:
-No HPFP issue.
-Rain/water flow, side windows
-Arm-rest
-Base audio
-Head-rest
-Pot belly look, removal
And TRY to not add more weight.
      09-24-2010, 10:48 PM   #2
tomegun
tomegun's Avatar
Drives: 528, 428 GC
2014 BMW 528i  [0.00]
I'm curious, when is the next version supposed to be out? Is the M going to be based on this body style?
      09-24-2010, 10:58 PM   #3
Emerson
Drives: '10 BSM 135i
2010 135i Coupe  [0.00]
+1 to the base audio
Really sucks to see that my '10 model base audio had no tweeters, while the older models had them.
      09-24-2010, 11:37 PM   #4
UdubBadger
633
Drives: '04 330i ZHP
2004 BMW 330i ZHP  [9.50]
2011 135i  [7.46]
2008 328xi  [8.76]
yeah those all sound good. I'd like to see a redesign on the navi "hood" this one does next to jack shit on blocking any glare from the sun.
      09-24-2010, 11:38 PM   #5
UdubBadger
633
2011 135i  [7.46]
2008 328xi  [8.76]
retrofitting some tweeters is easy, I did it. Check out my mod journal in my sig.
      09-24-2010, 11:57 PM   #6
fatjoez
student
fatjoez's Avatar
226
Drives: e90
Get rid of the cheaper,heavier steel currently used as a cost saving measure.
an E82 shouldn't weigh the same as E92
      09-25-2010, 12:07 AM   #7
Emerson
Awesome! Will look into it
      09-25-2010, 12:28 AM   #8
UdubBadger
633
2011 135i  [7.46]
2008 328xi  [8.76]
pretty sure we're still lighter by about 200lbs...
either way, we should be right around 3000lbs anyway. I'm sure the reason they don't cut more weight is cuz then they'd be selling more 1's and less 3's.
      09-25-2010, 12:29 AM   #9
BMW86
Australia
398
Drives: RS3 Sedan / Macan S
There are plenty of flaws in the 135i but they are all minor. The 135i was never meant to be an all out sports car, it's a 1 series equipped with the M sport package with a bloody fantastic engine. Floaty suspension, RFT's, lack of LSD, louder exhaust etc - they are all things the ///1M will deliver.
The 2 things I'd like to see fixed in the next gen 135i are the HPFP and possibly easier ECU access! lol
      09-25-2010, 12:55 AM   #10
spiderz17
Not a BMW Insider
spiderz17's Avatar
Drives: X5 M50i
I thought BMW only put LSDs on M cars, meaning you'd have to move up to the next-gen 1M to get that. Plus I'm sure that would address the suspension issues as well.
I'd also add the headlights to the list. I like everything else about the 1 design (I don't even mind the cow-belly line), but the "startled cat" headlights just don't do it for me.
      09-25-2010, 12:59 AM   #11
UdubBadger
633
2011 135i  [7.46]
2008 328xi  [8.76]
ooo that reminds me. We need those jazzy tails the 3 series LCI's just got.
      09-25-2010, 01:59 AM   #12
bimmerboy
bimmerboy's Avatar
23
Drives: 135i
LSD, non-runflats+stiffer M-tuned suspension, better sound system, LED angel eyes, and ofcourse fixed HPFP
That's it, seriously. Car doesn't even need more power, it is a blast to drive.
And for those who say that B.S "bmw only puts LSD's in M cars", BMW also "vowed" never to go with forced induction on an M model, and also to never make an M SUV... Look at the X6/X5 M... Talk is cheap
--2009 BSM 135i--
-Manual, Sport Package, BMW Assist
      09-25-2010, 02:00 AM   #13
jameselee
Drives: 2011 Space Gray 135i
@spiderz17: I agree! I wish the headlights were more "mean"/aggressive looking, like the ones in your avatar.
I am disappointed that I felt I had to buy the BMW Performance Suspension to (hopefully) get awesome handling. I thought that's what BMWs were supposed to be known for, but I was not impressed with the sport suspension, and really didn't buy a RWD car to get understeer. (Admittedly, I've only test driven a few times, but I drove an S2000 for six years, so I know what good handling is.)
2011 135i 6MT Space Gray/Black/Aluminum | M-Sport | Premium | CA | Nav
BMW Performance [Suspension, Exhaust, Grilles, Mirrors, Spoiler, Shifter/Boot]
Ordered: 11 Sep | Production: 16-23 Sep | Released to carrier: 26 Sep | Awaiting ship: 1 Oct | In transit: 14 Oct | Prep. Center: 9 Nov | Delivered: 10 Dec
      09-25-2010, 08:18 AM   #14
Rawhide
Rawhide's Avatar
Drives: 2022 M340ix
This is my second 1er and I have a few peeves with the car, although minor.
1st, I really wish there was a practical way to disable the headlight washers. Ticks me off when I just finish waxing my car only to have fluid sprayed all over the hood, and in my 128 vert the fluid would actually go over the top of the windshield and hit the passengers in the face. I don't need them and I don't want them.
2nd, RFTs, 'nuff said.
3rd, the stereo could be better.
4th, an adjustable headrest. For me it sits too far back so I never use it.
Not the kind to go to the track, I just do some occasional spirited driving, so the performance is more than enough to keep me happy. But I certainly wouldn't argue with you guys over any mechanical enhancements you deem important.
EDIT: Oh yeah, the cupholders suck.
      09-25-2010, 08:24 AM   #15
banglemangle
Azerbaijan
15
Drives: bmw135
1. Move headlamp switch to "OFF" position prior to activating windscreen washer stalk. Voila!! no headlamp wash. Easy fixed :-)
      09-25-2010, 08:28 AM   #16
Rawhide
Rawhide's Avatar
Drives: 2022 M340ix
You are my Saviour! All hail banglemangle!
      09-25-2010, 10:01 AM   #17
fwmcb
fwmcb's Avatar
Drives: 2015 F30 328i X-drive
2010 128i  [0.00]
1. Rear fog lamps on North American spec cars
2. keep the 3.0L I6 in the 128, and maybe bump the power to 260hp plus for those of us who enjoy the naturally aspirated powerplant.
3. A dipstick Audi lets you pay $20.00 for one...
4. Retain the minimalist interior. I like that my 1er doesn't have any displays or anything too fancy or distracting. I really do not like the idea of letting people read e-mails over a nav display while driving.
5. But if they have to go and make the next 1er all techy I hope they give it a heads up display because they are cool.
      09-25-2010, 10:03 AM   #18
bimmer135i
bimmer135i's Avatar
Drives: bmw 135i
Fix the indention on the dash board! Thats my only complaint that really bothers me on a daily basis but except that the 1er is a flawless car.
      09-25-2010, 10:51 AM   #19
gnat
Drives: Wishing for an e30iX
The head rests bug me too, and I only just placed my order. My thought was to install a 3 headrest. Has anyone tried that to see if it works?
My list would be:
1) Better grab handles on the doors as the current ones are way too far forward to nicely control opening and closing the doors in windy conditions.
2) Put it on a weight loss program. ~200lbs less than the 3 is a joke given the size difference. There has to be weight they can cut.
3) Following on #2, don't start with the bloat. The 3s are pigs to what they used to be and the handle like it too, don't do the same to the 1. I would happily live without most of the modern conveniences for a "truer" car.
      09-25-2010, 12:29 PM   #20
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
The 335i coupe is 5.5% longer than the 135i coupe and weighs 5.3% more. Not much difference.
Sounds like you really want "de-contented" 1 and 3 series, but BMW knows they won't sell in the US. So the real problem is as Walt Kelly said years ago: We have met the enemy and he is us!"
Personally, I'd like to see with a temp gauge on both my 128i and 328i - even the old heavily buffered water temp gauge was better than nothing.
Tom
      09-27-2010, 09:28 PM   #21
RPM90
My list would be:
Looking at the pics of the F20, it looks like the headrests are different.
Better? Don't know yet, but I hope so.
      09-27-2010, 10:31 PM   #22
Brad135
Brad135's Avatar
Drives: 2015 FiST
Honestly...BMW needs to separate the 1er and 3er pricing by a larger margin. And I don't mean make the 3er more expensive.
I agree with most of the wish lists so far...keep them coming.
1addicts
