BMW 3-Series (E90 E92) Forum
Help! 18x8 et20 (f) 18x9 et22 (r) fit e90?
10-30-2010, 06:12 PM | #1 |
Rep 265
Will 18x8 offset et20, 74.1mm hub size fronts, and 18x9 offset et22 72.5mm hub size rears, fit '07 e90?
The car is on stock suspension but do plan on lowering. Also, will probably run stock tires sizes (225x40, 255x35). Thanks! |
10-31-2010, 12:10 PM | #2 |
Rep 29,202
I'm gonna say yes, of course you'll need hubcentric rings on the front.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
11-01-2010, 05:44 PM | #3 |
BimmerPost Supporting Vendor
2050
Rep 25,989
Fronts are a bit aggressive but you may be able to pull it it with that 225. The rears are 5mm more aggressive then the general recommended fitment of 9.5" +33 but since you are running a 255, you should be perfectly fine. Like Remmib said, you'll need hub rings up front.
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
