BMW 3-Series (E90 E92) Forum
I fixed my squeaky seat is 3 minutes. Here’s how
06-01-2007, 07:58 PM | #1 |
Thats all you need to know.
43
Rep 1,188
Someone else posted they were hitting everything under the seat with WD40 and got the squeak to go away. I did a systematic approach to see if I could find the location that was the problem. I oiled 7 spots and the 7th spot cured it. I first oiled the 4 hinges that lift the seat up, 2 front 2 rear. I oiled the top and the bottom joint. No difference in the squeak. I next oiled both side of the bar that runs across between the hinges that lift (left to right in the front). No Difference in squeak. I next oiled the spring located on the console side of the seat in the front, it clips on a tab that is very easy to see. Squeak gone.
I obviously cant ensure it will cure your seat but a can of 3 in 1 oil or WD40 and a few strategic shots and you could save a trip to the dealer Raise the seat all the way and move it back or forward to get easy access to these locations.
- M2 2018 LBB / Black
- X5 F15 2016 Mineral White / Black 1981 Delorean number 6489 |
06-01-2007, 08:01 PM | #2 |
Member
310
Rep 22,825
Good job and thanks for the tips!
I'll give it a try, but start from you 7th spot. I recall reading that someone had a spring replaced to resolve the problem. That may be the one. |
06-01-2007, 08:04 PM | #3 |
Trance Life
315
Rep 4,706
God, I hate my stupid squeaky seat. I feel like I'm gonna turn into the Hulk and smash the car into pieces every time I get in. Thanks for the tips. What kind of "oil" was used?
06-01-2007, 08:07 PM | #4 |
43
Rep 1,188
I used a Permatex oil that is like WD40. WD40 is actually not really oil but it's easy to apply and it will do the trick.
06-01-2007, 08:14 PM | #5 |
Rep 463
Do NOT use WD40. Your car will stink for a couple of weeks.
Ask me how I know Once that didn't work, I got a spray can of lithium grease - the kind with the little straw. That worked, and didn't stink. |
06-01-2007, 08:48 PM | #6 |
Trance Life
315
Rep 4,706
