BMW 3-Series (E90 E92) Forum
E46 M3 squared 19x9.5 on an E90? Thoughts?
06-08-2012, 04:36 PM | #1 |
Rep 19
I happened to come across a guy selling some sick ass OEM E46 powder coated 19x9.5 squared setup (two sets of rear) off his M3 - 255/35/19. As far as I can see, the 19x9.5 ET are 27...my E90 is 34 and 37 - 205/55/16, F & R.
Now, I see this type of question on here a lot, especially lately since I've been looking more. What sort of spacing will I need here for the front and rear on the E90? Is fender rolling necessary? This is what the wheel offset calculator read: Rear - 22mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 42mm Front - 25mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 39mm Is this ridiculous? Any help is appreciated! Last edited by Rainerelliott; 06-08-2012 at 09:22 PM.. |
06-11-2012, 10:23 AM | #2 |
Rep 9,097
Rear should be fine and pre-LCI E90 can take ET27 easily.
For front, you can give it a try and I am sure they will be fine, though they will be 2-3mm away from the struts. In worst case scenario, you can use 3mm spacers at the front to fit them.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
06-11-2012, 02:34 PM | #4 | |
Rep 2,823
To OP Here is one with 225/40/18 tyres and 18x9.5et27 wheels front http://www.stanceworks.com/forums/sh...d.php?p=525546 Here is mine with 9.5 et35 with 235/40/18 yours would stick out 8mm more http://www.e90post.com/forums/showpo...45&postcount=4 But you cant use those tyres (255/35/19). You need narrower like 235/35/19. You probably could fit wider but it requires messing with camber/rolling fenders etc. |
