BMW 3-Series (E90 E92) Forum
Questions about offsets and spacers.
08-20-2007, 07:27 PM | #1 |
Rep 1,914
I have narrowed my choices in wheels to either CSL reps, Miro 366s and Moven BRS wheels 19" staggered 8.5' front 9.5" rears. At the moment, I am leaning towards the Movens but the front offsets are ET 40(which I believe is ok, and the rear offset is 44). If my logic is correct, should I get 12 mm spacers which would give me an effective 32 offset? 15 mm spacers would give me a 29mm offset which I believe might be to aggressive for the E92 with the General Exclaim UHP tires. Also, since I am really inexperienced in the use of spacers, are thee spacers sold in pairs(makes sense to me) or are prices that I have seen on **********s per spacer? I figure that I will also need longer bolts/studs.
08-20-2007, 07:41 PM | #2 |
67
Rep 1,334
Your logic is correct, in the method of which you are going about fitting these wheels onto your car with an aggressive offset.
Just to make sure. I would order the wheels first (which you should order from us ) Then mount it onto your car, and confirm your predictions, that a 12mm spacer will indeed fit. I recommend this, since every car is slightly different, and this is just a little extra insurance, unless you want everything asap! haha. I am also assuming you are going with the 235/35/19 tires in the front and 265/30/19 tires in the rear right? Yes, our spacer prices are priced per pair, and most all others should be priced per pair as well. We also have longer bolts/studs on our site, under the same category/section. Let me know if you need help with anything. thanks. -Don |
08-20-2007, 09:20 PM | #3 | |
Rep 2,278
2015 f80 M3, 2016 GT3
08-20-2007, 10:38 PM | #4 | |
Rep 1,914
