BMW 3-Series (E90 E92) Forum
Misfires
01-25-2013, 08:41 AM | #1 |
Rep 426
Drives: 2008 BMS E90 335i AT
Misfires
So, with my Cobb installed, I get misfires on 4 and 6. This originally started after running Stage 1+ with FMIC. I reduced it to Sport and it went away for a while, but came back a month or so later. It now does it all the time with the Cobb installed, but never has a problem at stock config. Took it to BMW for other problems (brake job/etc) and they couldnt find any problems with the coils/plugs since there were no codes being thrown or CELs. I know plugs were done 20k ago, but coils have never been replaced. I'm looking at coils as being the problem... Trying to get input of others that have had similar issues while under warranty to see what I should do. At this point I have left the Cobb uninstalled and keep praying to see a CEL at some point in time so I can get BMW to replace the coils... that $750 Cobb is burning a hole in my pocket though...
On a slight tangent - anyone got an idea what coils cost? I remember looking them up a year ago for my `07 and they weren't hella expensive, but weren't cheap either... Thanks ahead for anything constructive criticism anyone can offer.
2007 JB e90 retired! 2008 BMS e90 stock for now |
01-25-2013, 09:16 AM | #2 |
Rep 1,032
Drives: 2010 335i Coupe/Space Gray
I'm getting a cyl 4 misfire code quite often too. I'm about to uninstall the tune to see if it happens running stock ECU settings.
COBB Stage 2+ AGGRESSIVE / STETT Cold-Air Intake / STETT Charge Pipe / TiAL Blow-off Valve / ETS 5" Front-Mount Intercooler / Active Autowerke 3" Catless Downpipes / Active Autowerke Signature Exhaust / AST 4100 Coilovers / OS Giken Superlock LSD / All MOTUL Fluids |
01-25-2013, 12:33 PM | #3 |
resident girl.
59
Rep 1,017
Drives: 2008 335i + 2014 X5
Have you had your intake valves cleaned? I wasn't seeing misfire codes, but was getting small "hiccups" -- and occasionally larger ones that really felt like misfires, but no codes being thrown -- with Cobb installed, running Stage 1 Aggressive + FMIC (mine also diminished or went away when Cobb was uninstalled). Had intake valves cleaned in December and the issue has not resurfaced. Coincidentally, cyls 4 and 6 were the nastiest looking IIRC.
Also, if you want to confirm a bad coil, reinstall your Cobb and swap coils on 4 & 6 with 3 & 5. If the misfire codes pop up on 3 & 5, there's your answer.
2008 E90 335i // Black Everything // photos COBB tuned / QTP e-cutouts / Helix FMIC / cp-e DCI / AWE BOVs / Catless / FBO + F15 X5 xDrive35i |
01-25-2013, 12:57 PM | #4 |
Rep 426
the guy who had my car before me actually had the walnut blast done before i bought it. Im too lazy to swap coils (lol) but I'm pretty sure thats it... if not, it'll just be bad plugs (but i doubt it after 20k, but you never know.) either way, i'd rather BMW pay for it since I have it covered. Thanks for the advice!
01-25-2013, 03:06 PM | #5 | |
Rep 1,032
EDIT: How much of a pain is it to swap coils?
01-25-2013, 03:31 PM | #6 |
resident girl.
59
Rep 1,017
Swapping coils takes all of 10 minutes (half of which is tearing down the microfilter etc). You could just follow the spark plug DIY up to the point where coils are popped off
01-25-2013, 03:31 PM | #7 |
Rep 426
I did my plugs in my `07 and it was literally a 15 minute job. Considering you have to pop your coils off to get to the plugs, maybe 10 minutes? Pretty simple, just search for a plug DIY and you'll see.
01-25-2013, 03:31 PM | #8 |
Rep 426
LMAO JINX
01-25-2013, 03:36 PM | #9 |
Rep 1,032
awesome. thanks guys
01-27-2013, 03:52 PM | #10 |
Rep 2,633
i've got the spark plug tool dan if u need it. i think like 10-15 ppl have used it since i've bought it...i've yet to use it still lol.
e92, e90, f30 #DieselLife, e46, f80
01-27-2013, 08:50 PM | #12 |
Rep 1,175
I've seen a good number of recommendations to change plugs on 20K intervals with a tune installed. I kept getting misfires on cyl 1 during cold starts, to the point where the car would stutter and illuminate the CEL at low loads. New plugs resolved that issue completely, no coil swaps needed.
01-27-2013, 10:10 PM | #14 |
Rep 1,032
Plugs are new. Coils are my next likeliest suspect.
01-28-2013, 09:25 AM | #15 | |
Rep 426
