BMW 3-Series (E90 E92) Forum
Split Suspension Boot?
02-02-2013, 11:44 AM | #1 |
Rep 298
02-02-2013, 01:59 PM | #2 |
Rep 3,200
Drives: E92 325i MSport Coupe
You don't need to. This boot isn't split, just a little wrinkled at the base. It will cover the damper once you lower the car. Raising the car extends the spring, exposing the damper rod.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
