BMW 3-Series (E90 E92) Forum
Need help from the wheel & tire experts
02-18-2013, 02:20 PM | #1 |
Rep 1,369
Hi,
FIRST: Im currently running 20s on my e90 prelci. 20x8.5 et35 245/30 front and 20x10 et33 285/25 rear. Is there a way to run a wider rim in the front on a pre-lci? SECOND: If I want to go back to 19s and run 19x9.5 et35 front and 19x10.5 et27 rear, what size tire can I use that wont have the stretch look to it? Will I need spacers up front? Thanks in advance for any help
02-18-2013, 03:01 PM | #2 |
Rep 2,823
Im no expert ,but anyway. You have coilovers right?
Then you need spacer to front, otherwise it will hit the shocks.9.5 et35 is 2mm from stock shocks. 3-5mm spacer should be enough (don't know exact thickness), but with 10mm spacer you get hub centric one. Here you go many examples. http://www.e90post.com/forums/showpo...21&postcount=2 This E92 with 19x9.5 et35 and 245/35/19 http://www.e90post.com/forums/showth...=679925&page=2 But if you decide to use example 10mm (et25) spacer you are not able to use very wide tyre. 235/35/19 is probably the max and if you add even thicker spacer then 225/35/19. Unless you add more negative camber. 18x9.5 et20 225/40/18 and 18x10.5 et20 245/35/18 http://www.e90post.com/forums/showthread.php?t=737286 This one has basically the exact setup you are thinking http://www.e90post.com/forums/showthread.php?t=801899
02-18-2013, 03:19 PM | #3 | |
Rep 1,369
To answer your question, no I have H&R springs and Koni FSD What about the rear tires for 19x10.5 265/30 or 275/30? Thanks
02-19-2013, 11:56 AM | #4 | |
Rep 2,823
As for the rear.Both are used. http://www.e90post.com/forums/showpo...14&postcount=9 http://www.e90post.com/forums/showpo...37&postcount=5 http://www.e90post.com/forums/showthread.php?t=791857 http://www.e90post.com/forums/showthread.php?t=252394 Difference in diameter would be smallest with 235/35/19 front and 275/30/19 rear. Only 0.02 inch.With 265/30/19 you get more clearance and tyre stretch would be similar to 235 front.
