E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Florida > Tires n wheel help 20x10.5 tire size ?
Reply
      02-22-2013, 10:57 AM   #1
kennyray712
kennyray712's Avatar
Drives: clean 335i 4door widebody vm t
Hey would a 255/35r20 fit or Is the 35 to high ? On a 20x10.5 I'm lost ? Need help
My cars the e90
With kw v2 lowered fully with rear camber kit
Need to kno if a 265 or 255 or 275
30 or 35 by 20
Note needs to stretch a lil to clear fenders not fenders r rolled thanks again
      02-22-2013, 12:20 PM   #2
GetSomeE92
Drives: '09 Space Gray E92
A 255 width tire is way to skinny for a 10.5 inch wide wheel. It'll look terrible. At least go with a 275 width.
335i Coupe, JB4 (G4, map 5) DCI and 40% E85 blend: 2009 BMW 335i Coupe: 12.173 @ 109.490 MPH
      02-22-2013, 01:35 PM   #3
kennyray712
Thanks n do u think a 35 is good ?
      02-22-2013, 03:05 PM   #4
GetSomeE92
I'm not certain, but I think that would be too much sidewall to fit in these wheel wells.
      02-22-2013, 09:05 PM   #5
JohnSprm69
Drives: AW e92
i'm running 285/25/20 on my 10.5" rears, im lowered on h&r and had to roll my fenders.
      02-23-2013, 10:51 AM   #6
mikeyraw215
mikeyraw215's Avatar
Drives: 2006 bmw 325i (e90)
I used to run a 255/35/20 on my 20x10.5 +35mm offset and I was slammed on h&r race springs on stock sport suspension so it's like 1.5" drop and I had to have the fenders rolled and have some negative camber. So it really all depends on offset.
I ended up putting some lil spacer blocks in the rear springs and went down to a 265/30/20 and straighten out the camber and I like this set up better. Also I only added the spacers in the springs to boost up the rear a lil cuz of the weight of my system.
*TEAM SKAR AUDIO*
* Broadway Static coilovers with upgraded swift springs * M3 front control arms & rear guide rods * GodSpeed adjustable toe arms & camber arms * Forgestar cf5 18x10 & 18x12*
      02-23-2013, 09:34 PM   #7
kennyray712
Thanks. N it's a 42 offset
      02-24-2013, 08:16 AM   #8
mikeyraw215
Willtheyfit.com
Check this out
Www.Willtheyfit.com
Here is a comparison of my old set up vs. Your set up if u ran a 275/30/20
20x10.5 255/35/20 +35mm vs. 20x10.5 275/30/20 +42mm
Here is a comparison of my current set up vs. Your set up if u ran a 275/30/20
20x10.5 265/30/20 +35 vs. 20x10.5 275/30/20 +42mm
*TEAM SKAR AUDIO*
Reply
e90post
