F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - Florida > Coding in Tampa.
GetBMWParts
      03-19-2013, 05:54 PM   #1
Jparker82
Drives: 2019 X6M
Coding in Tampa.
Does anyone do coding in the Tampa area.
      03-24-2013, 07:42 AM   #2
ArchJR
Drives: 2024 i4 xDrive40
I second that question. There are a bunch of little software changes I would like to make.
      10-21-2013, 06:50 PM   #3
jetbill
jetbill's Avatar
198
Drives: G80 M3
+ 1 for some F30 coding in tampa
      10-21-2013, 09:09 PM   #4
sfr002
Drives: 2013 328i M Sport
With you on that! Closest I have found is PSI in Orlando, but the car has to stay overnight.
      10-22-2013, 04:06 PM   #5
kapkanimd
Drives: 2020 M8 Competition Gran Coupe
I am in Tampa and I have coded my car... Not sure how technical you are wanting, but it is pretty straight forward. I have cable and software.
      10-23-2013, 09:13 PM   #6
EHDEN
EHDEN's Avatar
Lebanon
394
Drives: 435i
2014 BMW 435i  [7.00]
not bad. i'll check with our Tampa chapter rep and see if he knows anyone up there also that can help...
      10-24-2013, 09:09 PM   #7
chris4prez
chris4prez's Avatar
Drives: 2014 335i M SPT - PPE/PPK - AW
      10-24-2013, 10:46 PM   #8
kapkanimd
If anyone in Tampa wants to meet up for some programming just send me a PM, so far I have done video in motion and auto folding mirrors with door lock/unlock
      11-13-2013, 09:11 PM   #9
kapkanimd
UPDATE:
Had a little coding fun this weekend with my and my friends F30s. Pretty straight forward coding multiple cars.
Things coded this weekend:
Car always starts in ECO mode (for my hippie friends)
Activate Sport + mode in non-sport (me of course)
TPMS shows actual pressure and temp
Car ringtone matches iphone ring tone
GPS clock matching
Some more mirror open close with door locks
and I have done video in motion before as mentioned.
If anyone in Tampa area wants any coding done I am pretty comfortable with it now. Just send me a PM
      03-04-2014, 07:25 AM   #10
dmath
dmath's Avatar
Drives: A supercharged box of giggles
Kapkanimd - can you code all doors unlock when ignition turned off? Would love to get that change done.
2014 328i M Sport
      03-04-2014, 04:10 PM   #11
kapkanimd
2014 328i M Sport
I certainly can, it is reported to work, but yours would be the first I have personally done it to.
In addition, I have done a lot more coding since I started this thread including:
flashing brake lights on hard braking
enable sport + mode (in non sport line/m-sport cars)
enable sport automatic transmission
enable launch control (a lot more complicated than regular coding though)
and a lot more..
      03-04-2014, 09:27 PM   #12
dmath
dmath's Avatar
Thanks for the reply. Maybe we can try to get together in April or May. There are a few changes I'd like:
Doors unlock with ignition off
Disable Nav startup screen
Flashing brake lights
TPMS pressure/temp display
Has the sport auto trans been confirmed as a software only change from the standard 8AT? I've been trying to find documentation on that but haven't seen anything definitive.
Holy #&%@, it's flat.
      03-16-2014, 04:35 PM   #13
XenaBimmer
XenaBimmer's Avatar
Drives: '14 328i, '14 320i
I'd be in for some coding as well!
2014 BMW 328i Sportline--Arctic White/Black, 8 speed
      03-16-2014, 04:47 PM   #14
kapkanimd
Yes, I have been using the sports auto trans for months now, it is definitely a noticeable improvement that I would recommend.
I am in and out of town until April so that would be best for me. PM me your details anytime in April to arrange a time to set it up.
      03-17-2014, 05:52 PM   #15
XenaBimmer
XenaBimmer's Avatar
Sounds good thanks!!
Is there a thread that lists everything possible for coding?
      03-31-2014, 05:43 PM   #16
kapkanimd
I am back in town and able to do coding for some peeps.. Just send me a PM and we can arrange something.
As far as what can be coded, there is info spread out, but for the most part you can look at the description using the database found here, www.bmw_codingdatabase.com/ (just remove the underscore between bwm and coding)
Otherwise you can look through the 281 pages found here: http://www.f30post.com/forums/showthread.php?t=696777
I can also bring a list with me that shows everything
      04-25-2014, 09:30 AM   #17
PDACPA
Drives: F33 M Sport 435i
Can the dealer tell that you have made changes to the coding (giving them a way to void the warranty)?
2014 F33 Blk/Blk MSport 435i (sold)
2012 135i Blk/Blk
      04-25-2014, 11:14 AM   #18
roxxor
roxxor's Avatar
1141
Drives: 2024 iX50
From my understanding(someone correct me if I'm wrong), yes the coding can be traced even if you go back and undo it before you take the car in for service. Chances are, if you just go in for an oil change or something minor, they won't say anything about it. I had my car in to have my glove box lock replaced and they didn't say anything about mine, but mine aren't majorly noticeable changes(M performance logo on instrument panel being the most obvious, Tire Pressure/Temp display, video while driving, comfort access windows up with remote, other small things). If you were to go in for "Hey my head unit stopped working" and they found that you had coded it, then chances are they would try to deny it under a warranty claim.
Additionally, if you have the car in for service and they do a software update, more likely than not it will clear away your coding meaning you would have to go back and do it again with updated software.
      04-29-2014, 06:27 PM   #19
XenaBimmer
XenaBimmer's Avatar
I'm wanting the following things coded. Are these possible and am I missing anything else big?
-audio starting at last position when car is started (at current playback if using iPod)
-auto folding mirrors with lock/unlock
-TPMS showing psi and temp
-disable warning screen on iDrive at startup
-ASS work in Sport mode
-ability to configure Sport mode in iDrive menu
      04-29-2014, 07:34 PM   #20
kapkanimd
The only ones I am not familiar with are the last position of the radio and the ASS in sport mode. I am sure they are both possible, but I know the ASS thing is something that is new as mine works in sport mode (unless you mean the sport mode with the shifter to the left). Other than that there are numerous options to code. I can show you a list if we agree to meet up to code or you can do more research now.
      04-29-2014, 08:21 PM   #21
XenaBimmer
XenaBimmer's Avatar
Thanks for the info!
So your car will turn off (ASS) when stopped in Sport mode (the button not the shifter to the left)? Mine only will in Comfort or Eco Pro
This thread talks about the current playback coding http://www.f30post.com/forums/showthread.php?t=950004
      05-02-2014, 11:33 AM   #22
kapkanimd
Still a little confused, nothing/no mode turns off the ASS unless you physically push the button to turn it off, put the car in neutral, or push the shifter to the left, otherwise it is always on. This is how it was when I got the car. I was hearing that there was an update that does what you say (disables ASS in sport mode), I am not sure if there is coding yet to turn it back to the original mode (how mine currently is). I will look into it though if that is what you are asking for.
f30post
