BMW 3-Series (E90 E92) Forum
Here are TPM pics and info
10-18-2007, 08:43 PM | #1 |
Rep 207
There are tons of posts out there regarding TPM's. I was confused and hope that this post helps with information about TPM's for the E90.
First, I have a post March 2007 335i sedan. My car does have TPM's. I purchased new tires from Gary at the Tire Rack and the appropriate TPM's and valves for my car (I am using BMW Style 161 wheels for my winter set). The TPM's and valves sold by the Tire Rack are OEM parts. The TPM's show up as two pieces and need to be purchased as two pieces, the TPM sensor and the appropriate metal valve. I have attached pictures for reference. The BMW part number is on each box: TPM Sensor - 36 23 6 779 490 TPM Valve - 0535.007.001 Tire Rack part number: TPM Sensor - BMWSEN1 (~$38 each) TPM Valve - RDV001 (~$8 each) To be clear, you will need four of each part for four wheels. The parts are made by Beru for BMW. I have also attached the data sheet for the TPM's from www.Beru.com which shows how to install. One item to note is that the valve came with two washers. These washers from what I can tell are not both supposed to be used and are not duplicated of one another. Reading the data sheet from Beru shows that one washer has a 45 degree bevel around its circumference and the other washer has no bevel (or 90 degree). For BMW, you use the washer with no chamfer. The Beru sheet shows installation. You take the valve apart and put it through the hole on the wheel then thread the valve back on to this part using the washer and the little rod in the package to hold the inside part of the valve in place when tightening the valve from the outside using a wrench or socket. The sensor attached on the other end using the supplied Torx screw. Adjust the angle of the sensor appropriately per instructions and tighten torx screw completely. I hope this helps with future questions. -Mark |
10-18-2007, 09:08 PM | #2 |
Rep 582
Drives: 08 E90 AW 335i 6MT
Nice post. I found that same pdf from beru a few weeks ago. I noticed my valve stems from Tischer only came with one washer and also had bmw stamped on the boxes. This would be a great addition to the DIY section!
10-18-2007, 10:31 PM | #3 |
Gruppe Titan
264
Rep 2,839
Drives: 08 E92 SG/Coral
This should be a sticky!
Good Stuff!! |
10-19-2007, 07:52 AM | #5 |
Rep 207
I believe TPM sensors are now standard on all E90 3 series post March 2007 vehicles.
Of course you can use the sensors from the stock wheels, but if you are buying a second set of wheels and tires for the winter, the best option is to get a second set of sensors, otherwise you need to disassemble the wheel for each season. Summary...If you want two sets of wheels, one for winter and one for summer for instance, then you will need a second set of TPM's to make life easier, cheaper, etc. Then all you have to do and jack your car up, swap out the wheels when the weather changes. It is a 30 minute job. |
02-23-2008, 11:22 AM | #6 |
Rep 3,201
If I swap from my TPM-sensor-equipped wheels to my winter set which are also TPM-sensor-equipped, what do I need to do to get the car's RF receivers to detect the new sensors? Or are they all very short range and all use the same coding system? My car came with 16" OEMs and I'm upgrading, but want to use the 16" for winter tires in future.
02-23-2008, 03:22 PM | #7 |
18
Rep 300
are you saying their are different types of BMW metal valves?
ROLLING STOCK |
02-23-2008, 03:38 PM | #9 |
18
Rep 300
http://img504.imageshack.us/my.php?image=photo90xt2.jpg
this is what my TPM looks like. its a tad different. i bought them used. will these work?
ROLLING STOCK |
02-23-2008, 03:59 PM | #11 |
Rep 7,519
Drives: 2009 E90 335i MT
If all four modules use the same frequency (433 MHz), how does the car know which wheel is sending which signal? What happens if the BMW next to you at the traffic light has a flat tire?
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
02-23-2008, 04:17 PM | #12 |
Rep 207
If you purchase a second set of wheels with TPM sensors, then there is nothing you need to do for the car. It automatically recongnizes the new sensors when you do the TPM reset procedure. As far as knowing which wheel, it must use a proximity type of sensing meaning it must have a sensor close to each wheel and only senses for the TPM's within so many feet. When you do the reset it is identifying the sensor for future monitoring and will not confuse itself with others (I guess).
02-25-2008, 05:11 AM | #14 | |
Rep 251
The pressure dropped in one of my tires, triggering the system, but it did not tell me which tire was low. So I filled all of the tires. |
