BMW 3-Series (E90 E92) Forum
Are run flats repairable?
01-02-2014, 12:44 AM | #1 |
Rep 4
im asking this beacuase ive heard there not but i had a screw in one of mine and took it to les shwab and they patched it, is the tire safe?
01-02-2014, 08:33 AM | #2 |
42
Rep 367
No they are not repairable as far as i know. I had nails in mine and they had to be replaced. I promptly replaced them with standard tires lol.
01-02-2014, 08:55 AM | #3 |
7478
Rep 10,120
Yes they 100% are. My old 07 328 had run flats and I had a nail in one tire causing a slow leak. Took it to a shop and they patched it like any other tire. After it was patched I drove about 10k miles on it before getting new rims.
01-02-2014, 09:00 AM | #4 | ||
Curmudgeon and Pedant
690
Rep 3,489
Note that the tire needs to be broken from the rim so that the sidewall can be inspected for damage. A couple manufacturers forbid it: http://www.tirerack.com/tires/tirete...jsp?techid=226 |
01-02-2014, 10:17 AM | #6 |
Wheelbarrow Edition
60
Rep 1,608
My garage wont repair them as they cannot say how long its been run on flat for
Its a liability and legal issue! Say you got a RFT patched and a week later you had a blowout on the motorway and it resulted in a fatality (worst case) the garage would be liable and not many want to take the chance If i was a tyre place i wouldnt fix them either, all about covering your arse nowadays |
01-02-2014, 11:44 AM | #7 |
Rep 3,955
Yes they are unless the tire was driven flat for an extended period. Any black powder in the wheel when going to patch it and it is not reusable.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
01-02-2014, 11:47 AM | #8 | |
Rep 3,955
01-02-2014, 12:59 PM | #9 |
BimmerPost Supporting Vendor
2050
Rep 25,989
They are repairable for sure.
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
05-15-2014, 03:50 PM | #10 |
Rep 9
Drives: 19' Z4 30i SanFran Red/White
I just took my 335xi into JMK BMW today, here in New Jersey and my rft passenger rear, was losing air slowly...thought it was stem valve leak. Dealer/service tech called to tell me a nail hole was found in the middle. They said they could patch it. Tire is only 7 months old with less than 3,000 miles on it. I am surprised they said they would patch it but I'm glad they did.
05-15-2014, 06:20 PM | #13 |
Rep 686
Drives: 06 330xi (TRADED IN)
Had a scare last week:
https://www.facebook.com/photo.php?f...9&l=8d62de25d2 THANK GOD that it was a short screw and just got caught in the treads and I caught it as it make a clicking noise backing out of the driveway... But actually, if there's some notoriety to the shop's name chances are they won't patch it, but a mom-and-pop shop won't give you much BS... But it's all at the discretion of the shop either way, and from what I read on the subject matter last week, it's safe as long as it's not in the sidewall.
05-15-2014, 10:19 PM | #14 |
Rep 26
I had my '06 325xi right rear SSR tire patched after I found a nail In my tire. Fortunately it was not in the side wall, and the local BMW/Mercedes auto sales shop patched my tire for free! I have just reached 500 miles on the tire and no problems, no deflation, and no sensors going off! I'm waiting until summers over to get new tires (mostly because my tread is low) And who doesn't love a new pair of tires?
05-15-2014, 11:24 PM | #15 |
Rep 448
Drives: 335i Msport
Yes they are repairable.
05-16-2014, 07:30 AM | #16 | |
Moderator
369
Rep 4,745
Although I would change the wording a bit to include them being unrepairable when driven in a low pressure situation.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
05-17-2014, 09:55 AM | #17 |
Rep 715
The answer is IT DEPENDS.
A RFT can be repaired if it hasn't been run with low pressure for a long time. What is low pressure and a long time? Not sure. But the bottom line is that the lower the pressure and longer the length of time driven, the more the tire gives up its life to get you from point A to point B. The tire deteriorates. That's why manufacturers set limits to how long you can drive on a flat RFT. So, if you have a slow leak and keep the pressure near normal and the nail or screw is in the center of the tread, it CAN be repaired. But the key question is: "Will someone repair it?" As others have said, some shops will refuse because of liability reasons. Although there are some signs of deterioration if run at low or no pressure for long periods, some shops fear that some damage may have occurred that they can't see. None of the BMW dealers I checked with would patch them. I had to go to Indy shops. Here's what Bridgestone says: (http://www.bridgestone.com/sc/runflat-system/qa/) "It depends on how far and at what speed the car was driven after the puncture was sustained. Repair is possible only if deemed so by the tire sales store. Preconditions include a puncture of less than 6mm for both side-reinforced type and support-ring type Run-Flat Technology tires, plus minimal damage to the support ring in case of the latter. However, it is strongly recommended that the tire is replaced as its durability will have been weakened after being repaired." |
05-18-2014, 03:31 PM | #18 |
Rep 555
I was at Costco this morning and the guy there showed me a chart of the name brand tires that they sell. For Michelin they only allow one patch fix for RFTs and Bridgestone allows maximum of 2 patches for their RFTs. Regarding the Bridgestones he also mentioned that the distance between patches has to be more than 15". I figure that had to do with wheel balance?
05-25-2014, 09:46 AM | #20 |
Rep 555
Discovered a screw on my drivers side rear tire.
Also found out that no one will patch my oem Turanzas due to liability issue. After 82,000kms it's time for PSS's. |
05-25-2014, 03:03 PM | #21 | |
Came to the N55 Darkside
1115
Rep 12,740
Anything in the tread, no problem- treat as any other tire. Damage in the sidewall, as with any of her tire, get the hell rid of it and get a new one ASAP. The significant differences between run flats and regular rubbers are primarily in the sidewall anyway- they're not some super sophisticated form of tire beyond that difference |
