BMW 3-Series (E90 E92) Forum
E92 Wheel Spacer Question
04-08-2014, 08:55 AM | #1 |
2021 X5 M50i
63
Rep 183
I'm running 193's with stock Bridgestone Potenza RFT and want to add wheel spacers. I have read I can go as high as 12mm on the front and 15mm on the rear. I want to go as aggressive as i can without rolling the fenders. My car is stock height with sports suspension and i'm not planning to lower it.
Any insight would be appreciated. Thanks |
04-08-2014, 12:16 PM | #3 | |
I Can't Drive 55
129
Rep 883
Drives: 2008 BMW 335i (E90)
Garage List 2023 VW ID4 Pro [0.00]
2002 Ford F250 7.3L ... [9.50] 2008 BMW 335i [0.00] 2012 Mercedes ML350 [0.00] 2002 Toyota MR2 Spyder [0.00] |
2008 Black Sapphire 335i E90 Sport & Premium Pkgs - Cobb Stage 1+FMIC Sport map, Mishimoto FMIC & Alpina B3 AT Flash. See: My Build Thread.
04-08-2014, 01:07 PM | #4 |
BimmerPost Supporting Vendor
2050
Rep 25,989
The best method to figuring out what spacer size to run is to measure.
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
04-08-2014, 06:10 PM | #7 | |
2021 X5 M50i
63
Rep 183
I would check them after 50 miles or so though. |
04-08-2014, 08:57 PM | #8 | |
I Can't Drive 55
129
Rep 883
I just said that I thought that I "could" go w/18mm on my E90 but that might not work w/your E92. From what I've read and seen, you should be fine w/the 12/15mm combo on your E92 but I don't think I've seen a pic of anyone running w/18mm in the rear of an E92 yet. So, you should do your own research on that before committing to the 18mm's in the rear. The angles aren't all that great but you can some some pics of the 12/15mm spacers on my E90 here. Good luck!
04-09-2014, 08:28 AM | #9 | |
2021 X5 M50i
63
Rep 183
I appreciate all the help SSW! |
04-09-2014, 11:18 AM | #10 | |
I Can't Drive 55
129
Rep 883
By coincidence, I've lined up a pair of new 18mm RS Technik spacers for a good price locally and am going to give them a try. Update 04/09/14 - 18mm Rear Spacers installed: Uploaded some pics of the rear wheels w/the 18mm spacers that I installed today on the E90 to the same post that I previously mentioned here. It's subtle but it looks better (to me) than w/the 15mm spacers. Could actually go 20mm if I wanted but I think that's it. I'm running the stock OEM sport package. So, rubbing shouldn't be an issue because there's still a lot of room been between the fender and the tires BUT, it probably would be a concern if I lowered the car anymore (which I do not plan to do). I'm going to wait a awhile to see if there is any rubbing or not and, if not, I'll put the pair of VRSF 15mm spacers up for sale. Update 04/12/14 -- Rear Passenger Side Tire Rubbing w/18mm Spacer: Took the car on a drive on a twisty back road w/a lot of dips and surface irregularity and discovered that the right rear passenger side tire rubs when the car hits sharp dips; can see the rubbing on the tire and fender edge. No rubbing on the rear driver's side. Only happens on the rear passenger side tire when hitting sharp dips at speed. Will either have to go back to the 15mm spacers in the rear or just drive slower and more smoothly when hitting poorly paved and uneven road surfaces on the back roads.
04-11-2014, 07:26 AM | #11 | |
2021 X5 M50i
63
Rep 183
That's the look i'm going for, I want them to be flush with the fender. I'm hoping the 12/15 combo works for me. |
04-18-2014, 07:34 AM | #12 |
Collector
16
Rep 324
Drives: E39 540, E90 335
I think I'm going with a 10mm in the front and 15mm in the rear so you tell a difference
Instagram: bmwninja xbox: bmwninja ps3: bmwninja5
Cars I've Own: E39 525. E60 545. E92 328xi. E46 M3. E39 540. E90 335. |
