2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Picture of stock speakers and replacement
      04-10-2014, 12:03 PM   #1
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
I thought I would upload a picture of the stock speakers. The bottom pair is the door speakers and the top pair are the rear deck speakers.
I also included a picture of the Focal ISC 100 speaker that replaced the stock ones. I used the same speakers in the door and in the rear deck. It produced a remarkably better sound.
      04-10-2014, 12:09 PM   #2
dmboone25
dmboone25's Avatar
4972
Drives: 2024 Golf R / 2022 718 Spyder
2007 E92 328i  [10.00]
2007 328i  [10.00]
^^^ awesome - thanks for the pics - I was checking those out on Crutchfield earlier today. They have gotten really good reviews.
Do you happen to have a pic of the spacer your installer made for you? I wanted to get an idea of what worked for you so that I could potentially replicate it...
Also, did you replace the subs? Or are you thinking about it?
Thanks my man...
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
      04-10-2014, 12:37 PM   #3
DanG
DanG's Avatar
2018 BMW M2  [7.68]
I didn't get a picture of the spacer, sorry. I didn't replace the subs. But I now have great base so I don't plan on replacing them.
      04-10-2014, 12:59 PM   #4
dmboone25
dmboone25's Avatar
4972
2007 328i  [10.00]
No worries - you have been a big help regardless.
I am going to get under there and take a look tonight and see what's what on the sub front...
      04-10-2014, 04:07 PM   #5
DanG
DanG's Avatar
2018 BMW M2  [7.68]
A better picture of the new speakers from the Focal website:
      04-11-2014, 03:59 PM   #6
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
Did you buy a single Focal replacement for the center channel dash speaker as well?
Not bad on the Focals. I'm not a huge fan of coax setups since you can't amp and control the tweeters individually, but I trust Focal has a designed these properly. I'm putting these on my wish list and will probably drop in the 4" Diamond Audio Hex S400 speakers I have from an old install of mine, although those are a true component system. I won't really need the tweeters for rear fill.
      04-11-2014, 06:05 PM   #7
DanG
DanG's Avatar
2018 BMW M2  [7.68]
Didn't bother with the dash speakers. Kind of like the center speaker on your surround sound at home. They are not very important to the overall sound experience.
And you are right that separate control of the tweeters may be nice. But I wanted to keep the price reasonable and separate tweeters increased the speakers from $129 per pair to $600 per pair. I listened to both combinations in the show room but my ears aren't sharp enough to detect any significant differences. I am sure that if I had perfect pitch I probably could have. But I don't.
      04-13-2014, 10:01 PM   #8
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
Don't forget you've also got ambient noise to deal with in a car, if you can't tell in acoustically perfect listening room no way you'd notice in a moving car. Smart to save your $.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      04-14-2014, 07:54 AM   #9
disco4me
55
Drives: M235i
Do u think the Focal speakers sound better than the HK speakers?
      04-14-2014, 10:15 AM   #10
DanG
DanG's Avatar
2018 BMW M2  [7.68]
Quick answer, a big YES.
      04-14-2014, 10:34 AM   #11
bernstem
bernstem's Avatar
Drives: M2
I would agree that the center speaker in a car audio system is probably not as important as the door speakers, but for a home theater system, the center speaker is critical.
The center speaker carries all the on-screen dialogue and anything happening in the central image will be routed through the center speaker. You can often send a lot of that information to the left and right speakers if you want, but it will throw off the soundstage for anyone not sitting centered on the screen. An ideal front speaker setup for a home theater will have identical or nearly identical speakers for the center, left and right front.
      04-14-2014, 11:00 AM   #12
BEM-S4
BEM-S4's Avatar
+1. In my main theater I've got Sonance everywhere with beryllium tweeters, 2 subs etc. In my smaller setup I have a VMPS center and sub with Gallo left and right no surrounds. It's literally shocking how good the mini system sounds just with a great center and sub with a few not great, albeit very nice sides.
      04-17-2014, 02:48 PM   #13
valentinbmw
valentinbmw's Avatar
Chile
55
Drives: M3, F80
i would get this speakers in a heartbeatbut i am worried about the bmw warranty, do they void the warranty if you change the speakers?
2016 BMW F 80 M3 Current
2015 BMW F 36 435i Gran Coupe Retired
2014 BMW F 22 M 235 i Retired
2013 BMW E 82 135 i Retired
2012 BMW F 20 116 i Retired
2011 BMW E 81 116 i Retired
2007 BMW E 87 116 i Retired
      04-17-2014, 02:57 PM   #14
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
Warranty on what exactly? The engine? If you blow one of your aftermarket speakers, no, they won't get you a replacement speaker, but if you blow a gasket, it wouldn't be due to the aftermarket speakers.
Warranties are voided when you have a problem caused as a direct result of something you did outside of normal. Changing a speaker only voids warranty of those parts. A very impossible scenario would be that you installed some crazy speakers that changed resistance on the amp so much that the amp caught fire and your car was lost as a result. Just not going to happen though.
      04-17-2014, 03:23 PM   #15
bman6074
Drives: 14 M235i and 07 Lotus Exige S
Are these Focal ISC 100 speakers a exact swap or does the door panel need to be cut/modified. How does it look once installed?
      04-17-2014, 04:05 PM   #16
DanG
DanG's Avatar
2018 BMW M2  [7.68]
Exact swap except it need a spacer since they are deeper so they don't hit the window. No cutting and fits 100% behind stock door screen. Looks 100% stock.
      04-17-2014, 07:44 PM   #17
bman6074
Great thanks for the info
      04-25-2014, 02:48 PM   #18
bman6074
(Stock) How many speakers are there in the door? Is there a speaker in the triangle behind the side mirrors? Like in the 135i.
      04-25-2014, 04:48 PM   #19
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
I think there are seven total. None behind the sail panel with base stereo.
      05-13-2014, 09:17 AM   #20
bman6074
Does anyone know if the sail panel location is wired for a speaker and if so is it hot (live). I want to possibly find the sail speakers from a wrecked 1 series and just install them in the M235i.
      05-15-2014, 02:43 AM   #21
FoxCrane
FoxCrane's Avatar
Drives: Blue
Hey DanG, did you install these yourself or did you go somewhere? If you went somewhere, where did you go (assuming Seattle area)?
      05-15-2014, 08:58 AM   #22
DanG
DanG's Avatar
2018 BMW M2  [7.68]
Car Toys in Bellevue across the street from BMW Bellevue.
They have a life time installation guarantee.
2addicts
