04-19-2014, 09:12 PM | #1 |
Rep 775
DIY: M Performance Carbon Interior
Gents,
We currently have no DIY section; but I will post in the General Forum for the time being. These DIY's are done by a normal do it yourselfer. I do how ever have access to a hoist and by degree I carry a mechanical engineer background but I keep them geared towards the regular hobbyist. ---- Tools needed
---- Difficulty rating (1-5, 5 being hardest): 1 ---- I started with the center piece. This was done easiest by moving the arm rest to the back position and sliding my slim trim removal tool in. See below Once you have pried up enough to get the first clip out just start making your way back. The trim will come up quite nicely. Once the trim is lose, you will notice the iDrive wire is still connected to your trim piece. For sake of simplicity I removed the iDrive while still connected with a T20. It's held on by three obvious screws. Once the three screws are out the iDrive module will slip out nicely. Grab your new center console trim piece and install in reverse The driver side door vent is quite simple. Again, these are held on by only expanding clips and come off with little force. I always use my trim removal tool in a position if it were to ever damage any surrounding trim you wouldn't be able to see it at seat level. Start by opening the door and prying from the corner of the vent near the bottom. You will notice that this piece comes out extremely easy. Now you need to transfer over the vent. This is quite simple. The tabs are recessed inwards so pushing them down is quite difficult. The best way was the strip of the three tabs, I put my flathead vertical and pushed downwards on the vent (upwards on the connectors strip) and it popped out simply. With these removed the vent slides right out from its other five positional clips on the bottom. Install the vent in the new housing by sliding the five positional clips in the bottom than pressing the top three in firmly, making sure each one clips in. Next was the passenger large trim piece. Again, this one required very little force and simply slides out of it's clips. I started from the center outwards with my pry tool keeping my eye on the left corner to avoid damaging any of the surrounding trim. The vent will come out with the trim piece like the driver side. Again, slide your screw driver in the section of 3 clips and press upwards on the strip of connectors. The piece will slide right out.
14' M235I | BMW Performance Exhaust | BMW Performance Diffuser | BMW Performance Carbon Interior | ER DP |
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com Current: 2015 Cayman S on HRE P101 Last edited by Cripple; 04-19-2014 at 10:15 PM.. |
04-19-2014, 09:41 PM | #2 |
Rep 6,939
Drives: 2018 M2 AW DCT
Thanks for the nice DIY. The new carbon trim looks great.
bluesman826646.00 |
04-19-2014, 09:59 PM | #3 |
Vrooom :)
314
Rep 2,602
Great DIY!!
I'm considering getting this maybe! I think it will look good if the 2015 model comes with oyster/black! do you have any close up pics of the M performance sticking? If I remember I think I read somewhere they didn't like it (I think F30 post) because the M performance looked a bit floppy). Also - were you able to detach your black lower trim from the aluminum trim? I think some people were wondering if that part could be removable!
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
04-19-2014, 10:14 PM | #4 |
***** noob
1370
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Nice write up
We need a diy section...now
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
04-20-2014, 12:37 AM | #6 | |
templarklimek
142
Rep 868
04-20-2014, 09:51 AM | #7 | |
Rep 775
The lower black trim on the original is not able to be dettached, it appears that it's plastic welded together.
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com Current: 2015 Cayman S on HRE P101 |
04-20-2014, 10:49 AM | #8 |
Mbira
30
Rep 1,011
Drives: Sedonna Red 09 135i SOLD
Love it.....really nice. I am hoping this trim is standard on the M2...well at least the Alacantra like the 1M...But i will add the CF to it if not...Just beautiful, enjoy!!
04-20-2014, 12:01 PM | #11 | |
Rep 775
The door handles I'll update. I had them off due to already working on them. They are extremely simple. Place your removal tool at the bottom (there is an slot in the trim that allows you to put a tool in) and pry. The door handles will require the most force and you must slowly make your way up with the tool. Prying out each clip till you get to the top. There is a clip every 2 inches or so. Make your way slowly and they will pop right out.
04-20-2014, 03:42 PM | #12 |
Rep 775
Just picking up the wife from work. A better photo of the interior.
04-21-2014, 08:36 AM | #13 |
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
you got that right - man this looks good! Awesome write up.
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
04-21-2014, 08:50 AM | #14 |
Mbira
30
Rep 1,011
[QUOTE=Cripple;15816012]It took about 10 minutes for me to warm up to it, but now it's something I really appreciate. Sure Glossy would be nice but now I don't have to worry about yellowing. Not to mention, the texture to this trim is just beautiful. Feeling the weave is very nice!
Totally like the Matte CF much much better than the glossy especially for the interior. I put this same type of CF on my 135i really liked it. If it was glossy, it would not find it's way on my car.... |
04-26-2014, 08:27 PM | #15 |
Wingman
110
Rep 244
Drives: M235i
Garage List 2014 BMW 328d xDriv ... [0.00]
2004 BMW M3 Vert [0.00] 2007 bmw x5 [9.00] 2009 BMW M5 [0.00] 2014 BMW 335i xDriv ... [0.00] 2005 Honda Civic ex ... [10.00] 2014 BMW M235i [10.00] 2003 Mercedes Benz ... [0.00] |
is the carbon fiber trim lacquered or is it not?
2014 F22 M235i
2014 F30 335xi 2014 F31 328d // 2016 F85 X5M 2009 E60 M5 // 2004 E46 M3 2019 G05 X5 50i // 2017 Alpina B6 Gran Coupe |
04-26-2014, 11:23 PM | #16 |
***** noob
1370
Rep 10,479
OP, i notice your floor mats...are they weathertechs?
07-20-2014, 06:12 PM | #17 |
Rep 1,254
Anyone try this and have a tough time getting a trim tool under the center console piece. Mine is so tight up against the arm rest part I can't hardly slide paper in between it.
Any extra tips to help get it off?
07-20-2014, 07:12 PM | #18 |
Rep 1,040
If you don't have plastic trim tools try a old credit card to get it started. It takes a little force to get started by once you one clip up the rest can be pulled up using your fingers.
07-20-2014, 07:12 PM | #19 | |
***** noob
1370
Rep 10,479
2006 325xi (Sold)
07-20-2014, 07:50 PM | #20 | |
Rep 1,254
Gila tool the yellow card looking thing
03-14-2015, 03:44 PM | #21 |
Rep 1,797
Hey Op,
I think you've moved on from 2 series, but wanted you to know I used your pix and instructions to help guide me in installing the MP Trim today.. Well done and thx!!
Previous Rides: 535xi, M235xi, X3, E92 M3, E70 X5 35d, X6 50i, X6 35i, E60 550i, E46 M3 Cabriolet, E39 540i, E36 328i
08-29-2015, 03:26 PM | #22 |
Rep 793
Hi guys,
please can someone tell me how am I meant to install this i drive trim. I managed to install the all the other trims (vent, gear gaitor, handbrake etc) by levering the peices out with a trim remover but the I drive trim is very tight. As you can see from the pics, i can barely fit a piece of paper in the gap between the I drive trim and plastic - please advise I just cant see how I can fit the trim remover in to even get started. I am worried if I force it too much , it will damage the silver trim... Just cant see a way in... see the pics.. |
